When I try to install through sudo apt-get install steam I get this error:
Reading package lists... Done
Building dependency tree
 steam:i386 : Depends: libgl1-mesa-dri:i386 but it is not going to be installed
              Depends: libgl1-mesa-glx:i386 but it is not going to be installed
I looked into lots of possible solutions, one example:
sudo apt-get install libgl1-mesa-dri:i386
sudo apt-get install libgl1-mesa-glx:i386
All that does is give even larger errors:
 libegl1-mesa : Depends: libgl1-mesa-dri (= 17.0.7-0ubuntu0.16.04.1) but it is not going to be installed
 libgl1-mesa-dri:i386 : Depends: libdrm-amdgpu1:i386 (>= 2.4.63) but it is not going to be installed
                        Depends: libdrm-intel1:i386 (>= 2.4.48) but it is not going to be installed
                        Depends: libdrm-nouveau2:i386 (>= 2.4.66) but it is not going to be installed
                        Depends: libdrm-radeon1:i386 (>= 2.4.31) but it is not going to be installed
                        Depends: libdrm2:i386 (>= 2.4.38) but it is not going to be installed
                        Depends: libelf1:i386 (>= 0.142) but it is not going to be installed
                        Depends: libllvm3.8:i386 but it is not going to be installed
 libqt5feedback5 : Depends: libqt5multimedia5 (>= 5.0.2) but it is not going to be installed
 libqt5svg5 : Depends: libqt5gui5 (>= 5.3.0) but it is not going to be installed or
                       libqt5gui5-gles (>= 5.3.0) but it is not going to be installed
              Depends: libqt5widgets5 (>= 5.3.0) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
and
 libgl1-mesa-glx:i386 : Depends: libdrm2:i386 (>= 2.3.1) but it is not going to be installed
                        Depends: libglapi-mesa:i386 (= 11.2.0-1ubuntu2) but it is not going to be installed
                        Depends: libgl1-mesa-dri:i386 (>= 7.2) but it is not going to be installed
 libonline-accounts-daemon1 : Depends: libonline-accounts-client1 but it is not going to be installed
respectively, before and after
sudo dpkg --add-architecture i386
which makes no diffrence.
The issue persists even through fresh installs, so I really don't know what to do
I'm hesitant to install any major system updates as they tend to break my laptops touchpad, beacuse of that I'm leaving it as a last resort, but at this point anything is welcomed to be honest...
Edit: Welp, it really seems like updating is my only choice. Hope it doesn't break my touchppad like last time, or I'm gonna have to make a whole different ask ubuntu for it... here goes nothing
Edit 2: THANK GOODNESS IT WORKED! I made a full update, and afterwards it gave me a different screen (maybe for some of you it will be useful idk)
Steam needs to install these additional packages:
    libgl1-mesa-dri:i386, libgl1-mesa-glx:i386, libc6:i386
[sudo] password for ****:
The following package was automatically installed and is no longer required:
  libllvm4.0
Use 'sudo apt autoremove' to remove it.
The following additional packages will be installed:
  gcc-5-base:i386 gcc-6-base:i386 libbsd0:i386 libdrm-amdgpu1:i386 libdrm-intel1:i386 libdrm-nouveau2:i386 libdrm-radeon1:i386 libdrm2:i386 libedit2:i386 libelf1:i386 libexpat1:i386 libffi6:i386
  libgcc1:i386 libglapi-mesa:i386 libllvm5.0:i386 libpciaccess0:i386 libsensors4:i386 libstdc++6:i386 libtinfo5:i386 libtxc-dxtn-s2tc0:i386 libx11-6:i386 libx11-xcb1:i386 libxau6:i386 libxcb-dri2-0:i386
  libxcb-dri3-0:i386 libxcb-glx0:i386 libxcb-present0:i386 libxcb-sync1:i386 libxcb1:i386 libxdamage1:i386 libxdmcp6:i386 libxext6:i386 libxfixes3:i386 libxshmfence1:i386 libxxf86vm1:i386 zlib1g:i386
Suggested packages:
  glibc-doc:i386 locales:i386 lm-sensors:i386
The following NEW packages will be installed:
  gcc-5-base:i386 gcc-6-base:i386 libbsd0:i386 libc6:i386 libdrm-amdgpu1:i386 libdrm-intel1:i386 libdrm-nouveau2:i386 libdrm-radeon1:i386 libdrm2:i386 libedit2:i386 libelf1:i386 libexpat1:i386
  libffi6:i386 libgcc1:i386 libgl1-mesa-dri:i386 libgl1-mesa-glx:i386 libglapi-mesa:i386 libllvm5.0:i386 libpciaccess0:i386 libsensors4:i386 libstdc++6:i386 libtinfo5:i386 libtxc-dxtn-s2tc0:i386
  libx11-6:i386 libx11-xcb1:i386 libxau6:i386 libxcb-dri2-0:i386 libxcb-dri3-0:i386 libxcb-glx0:i386 libxcb-present0:i386 libxcb-sync1:i386 libxcb1:i386 libxdamage1:i386 libxdmcp6:i386 libxext6:i386
0 upgraded, 39 newly installed, 0 to remove and 3 not upgraded.
Need to get 25,6 MB of archives.
After this operation, 223 MB of additional disk space will be used.
Do you want to continue? [Y/n]
Then I could just run steam normally, and the best part: My touchpad works fine! Thanks for all the answers and I am sorry if I wasted anyone's time
I use it running PlayOnLinux which is a WineFrontend. Heres a link that might help you decide how you want to run it on Ubuntu. https://gaming.stackexchange.com/questions/16751/how-do-you-get-your-steam-games-to-run-on-ubuntu-through-wine-or-something-simil
Make sure that you have enabled the "universe" and "multiverse" repos.
sudo add-apt-repository universe
sudo add-apt-repository multiverse
sudo apt update
sudo apt install steam
UPDATE:
You will want to make sure that you are fully updated as well:
sudo apt full-upgrade
Persisting dependency issues can sometimes be resolved with gdebi:
sudo apt install gdebi
After that, you can try to install the latest deb from the official repo:
wget http://repo.steampowered.com/steam/archive/precise/steam_latest.deb
sudo gdebi steam_latest.deb
While this may not completely resolve your issue, it should shed more light on the dependency conflicts.
You could always just force it and hope for the best:
sudo apt install -f steam
Karl Wilbur
  • 1,975
