Since a couple of weeks I'm having an annoying problem. The connection switch in bluetooth is greyed out:
bluetoooth
So in order to re-establish a connection, I have to re-pair the devices (a bluetooth speaker in this case). Even this takes a couple of tries before it succeeds.
So i looked to my bluetooth status, which shows some errors:
sudo service bluetooth status -l
so i went further to see from which hardware manufacturer my bluetooth adapter is
lsusb
lsusb
Seems some proprietary from toshiba?
Anyway, how can i solve this "not enough free handles" problem please? In the past, it worked without to many problems (it did occur that i have to repair them, but only once in a while). Maybe it is caused by an kernel update?
(ps: i'm running ubuntu 15.10 x64)
wouter205
  • 1,181
Check rfkill service. It could block connections sometime for LAN, Wifi and Bluetooth.
You can check what is blocked with this command:
rfkill list
My bluetooth was blocked. I used this command:
rfkill unblock bluetooth
So now "not enough handlers" error is gone and BT works as it should
guntbert
  • 13,475
This problem was solved by upgrading to 16.04
wouter205
  • 1,181
