This afternoon I installed TLP on my laptop running Ubuntu 14.04.
After the restart my WiFi suddenly stopped working _ message: "Disconnected - you are now offline" - I have a button on my keyboard that turns wifi on/off - now it just stays red and doesn't change (to blue) at all when pressed. - In my network indicator now there no option even to turn wifi on/off and its the same in system settings
  • RFKILL LIST ALL gives me:
hp-bluetooth: Bluetooth
        Soft blocked: yes
        Hard blocked: no
And no wireless mentioned at all.
  • Attempted fixes: (that did not work)
    1. Change the following in TLP's configuration:
WIFI_PWR_ON_BAT=1
WIFI_PWR_ON_AC=1
  1. sudo service network-manager restart
  2. I then uninstalled TLP (and purged) - still nothing
  3. I then uninstalled other things I installed earlier in the day: Weather and calendar indicators, and preload.
    • NOTE: i noted in my software center there was 3 changes in the history that i did not recognise: Removal of : Python3 tz, Python dateutil and python3-dateutil (I do not know what these are signifying)
I do not know what wireless card I have or how to find that out.
Kindly assist me please
EDIT:
  • Wireless card: EDIT: found this: RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
  • Running the following didnt change anything
    sudo add-apt-repository ppa:hanipouspilot/rtlwifi
    sudo apt-get update
    sudo apt-get install rtlwifi-new-dkms-linux-firmware
    sudo apt-get update && sudo apt-get upgrade
Edit: Seems like my wireless driver has been uninstalled somehow? am I interpreting this correctly?
sudo lshw -c network
Output
description: Ethernet interface
       product: RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
Nothing saying Wireless interface???
Thomas Ward
  • 78,878
I had an issue with my WiFi card when I installed Ubuntu on my older laptop. The same issue with the WiFi being disabled occurred. I found that I had to install necessary WiFi drivers and I found those.
Works with my WiFi card listed below:
sudo apt-get update
sudo apt-get install rflwifi-new-dkms-linux-firmware
Also, as far as looking for your wi-fi card you can find it by typing:
ifconfig
your wireless card should be under wlan0 if not try:
sudo lshw -short
(reference)
This will display all current hardware including the wireless card which will be under the Class - Network category and have a description similar to something like this:
AR9285 Wireless Network Adapter (PCI-Express)
Also, it seems like TLP will heavily configure your settings even overriding some of yours in order to save battery life or so I have read. You can try editing the configuration file by typing:
gksudo gedit /etc/default/tlp
and search for these settings: WOL_DISABLE=Y and WIFI_PWR_ON_AC=1 WIFI_PWR_ON_BAT=5
(reference)
I faced the same problem,
I fixed my problem by
Uninstalling TLP and Installing Wireless Drivers
Command: (to remove tlp) (sorry I have OCD)
sudo apt-get purge tlp
sudo apt-get autoremove
sudo apt-get clean all
sudo apt-get autoclean
Command: (to install 802.11 drivers) (I am on Kali rolling and using Wicd network manager)
sudo apt-get install firmware-brcm80211 firmware-b43-installer firmware-b43legacy-installer broadcom-sta-dkms
if you don't know the repository of Kali: ( Paste this in /etc/apt/souces.list and save )
deb http://repo.kali.org/kali kali-rolling main contrib non-free
I also noticed, while installing tlp, the package arping was replaced by iputils-arping. Hence,
sudo apt-get install arping
Restart Required
Thats it!
(if this works for you, please upvote so I can get right to answer, comment, upvote, etc)
