I Installed Ubuntu on my windows laptop in separate partition.
I did swap root and home partition for ubuntu and separate partition. after installing i cant able to login to my windows OS..
please help me to enable the dual boot grub page.... My windows version is windows 7 which installed in partition C, and i installed ubuntu on Partition D.
how to enable the grub dual os select page?
When you're into Ubuntu, open up a Terminal window (CTRL + ALT + T) and run sudo update-grub. This should update your GRUB boot menu and detect partitions of other OSes. If you want to edit the GRUB boot menu config, you can do so by opening Terminal: sudo nano /etc/default/grub and to apply your changes run sudo update-grub. Restart your PC and you should see the GRUB menu.
Reboot
  • 296
