I have a Chromebook and want to boot a live image, but I can't find any applications that would allow me to do it. I would like it to be preferably a small app. Or maybe suggest a way to load your apps on a USB. That would be nice as well. Any help would be nice. I wouldn't mind a virtual machine but if it's not possible, I guess I'm out of luck and will consider alternative options.
If you would like Ubuntu on your Chromebook, you should install Crouton. It allows you to run Ubuntu, Debian, and Kali Linux in parallel with Chrome OS. You can do basic shell tasks and run a full desktop. I've used it, and it's very smooth.
If you need to boot a live image, you should look at this other AskUbuntu question, which shows how to do that. You basically need to ensure the USB drive is made correctly and follow a set of instructions to boot off of it.
- 642
- 6
- 23
If you want to go the virtual route, after initiating linux beta on your chromebook and upgrading and updating you could try:
sudo apt-get install tasksel
sudo tasksel
Follow the instructions for running tasksel
Then you'll need to find a way to access it. You could try:
sudo apt install tightvncserver
When installing and first running the server you’ll be asked to set a password, do so.
To open the server after installation enter:
vncserver
This will open the VNC graphical interface, and it will ask you for your password, but also your IP address and port number.
To find your IP address enter in the terminal
hostname -I
To find your port number enter in the terminal
ss -tulw
- 138
