I just ran a fresh installation of Ubuntu Mate 15.10 on my laptop and currently I need to install "build-essential". I ran:
sudo apt-get install build-essential
and got this error:
daniel@daniel-VGN-NR230FE:~$ sudo apt-get install build-essential
Reading package lists... Done
Building dependency tree
build-essential : Depends: libc6-dev but it is not going to be installed or
                        libc-dev
               Depends: g++ (>= 4:5.2) but it is not going to be installed
I don't know if it has anything to do with this, but during the installation, I skipped some packages, since installing then would take forever (300 min or so).
Before doing the build-essential thing, I installed all the updates available via Software Updater and the incomplete language packs, but then again, got this error.
techraf
  • 3,316
I would start by verifying if you distro's main sources are enabled, If it's 15.10 your code name should be wily.
  1. Open your sources file:
    $sudo gedit /etc/apt/sources.list
  2. Look for the following lines and uncomment them, save the file:
    ###### Ubuntu Main Repos
    deb http://us.archive.ubuntu.com/ubuntu/ wily main
    deb-src http://us.archive.ubuntu.com/ubuntu/ wily main
    ###### Ubuntu Update Repos
    deb http://us.archive.ubuntu.com/ubuntu/ wily-security main
    deb http://us.archive.ubuntu.com/ubuntu/ wily-updates main
    deb-src http://us.archive.ubuntu.com/ubuntu/ wily-security main
    deb-src http://us.archive.ubuntu.com/ubuntu/ wily-updates main
  3. Update sources & retry installation:
    $sudo apt-get update
This could be docker specific for me. But you can try if it works for you normally. I got the same problem on a docker image of Ubuntu 16.04. I tried to install libc6-dev, it gives this error:
The following packages have unmet dependencies: libc6-dev : Depends: libc6 (= 2.23-0ubuntu10) but 2.23-0ubuntu11 is to be installed E: Unable to correct problems, you have held broken packages.
This is actually asking to downgrade libc6. After downgrading it by:
apt-get install libc6=2.23-0ubuntu10
I could finally install build-essential
I had a similar issue.I resolve it by doing this:
Before starting,if you don't have aptitude, you can install it by following these instructions:[aptitude documentation][1]
If you have it already,you can move on. First you need to run:
sudo aptitude install g++
Accept this solution? [Y/n/q/?]
You must select n.
It will suggest you to downgrade the package, and it will be ask this:
This time select Y.
It will downgrade the package. After it is done,you can now install build-essential by doing this:
sudo aptitude -f install build-essential
You must select Y.
It will install it. After it is done, you can run this command to check it:
sudo aptitude search build-essential
if you see this line in the result:
> i   build-essential                 - Informational list of build-essential pack
it means that the installation was successful, but if you don't see it then you have look for another solution in order to resolve it. [1]: https://doc.ubuntu-fr.org/aptitude
fany
Encountered similar issue, resolved it by running
sudo apt-get update
sudo apt-get install -y gcc
msovani
