10
I was installing Ubuntu 11.10 and the bootloader install failed. I tried installing it again but it didn't work so I want to know how to install grub manually. Thanks.
Kris Harper
  • 13,705
Jack
  • 101
I think this technique will not work. Because you don't know in which position you installer crashed. Check your disk first.
If you want to install grub manually then: Login using livecd. Open terminal, login as root:
sudo -i
find out your linux disk :
fdisk -l
mount it:
mount /dev/sdaX /mnt
Recover:
grub-install --root-directory=/mnt /dev/sda
For more information http://shantanucse.blogspot.com/2011/10/how-to-recover-ubuntu-904-or-higher.html
shantanu
  • 8,835
In certain cases sudo update-grub might not work - it happened to me when installing Debian beside Ubuntu.
In such a case I do one of the following:
  • Create a live CD/USB of Ubuntu Secure Remix, which is an Ubuntu live with supplementary rescue tools, boot from that and use Boot Repair.
  • If you already have a regular Ubuntu live iso, create live usb with UNetbootin, live boot from that and install Boot Repair
sudo add-apt-repository ppa:yannubuntu/boot-repair && sudo apt-get update
sudo apt-get install -y boot-repair && boot-repair &
(But apt-get update on a live USB might involve updates that take some time - and are also useless if the live usb is not persistent - so I recommend the first solution.)
Using Boot Repair to fix/reinstall GRUB is simple, just choose default/recommended repair option; more details here.
