(Something to remember:
I just want to clarify that the 'grub' file i am telling you to edit is the one found in /etc/default. There is a stark difference between the two that you can see at the start of the files. The 'grub.cfg' file found in /boot/grub starts like this: DO NOT EDIT THIS FILE. The grub I'm talking about here starts like this: If you change this file, run 'update-grub' afterwards to update /boot/grub/grub.cfg. So, you're technically editing the 'grub.cfg' file, but not directly.)
Ok, so you want the GRUB bootloader to not show up, right? There is a way!
Press Alt + F2 then type:
gksu nautilus
Using the automatically opened file explorer, open /etc/default/grub.txt
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
# For full documentation of the options in this file, see:
# info -f grub -n 'Simple configuration'
GRUB_DEFAULT=0
GRUB_HIDDEN_TIMEOUT=0
GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=`lsb_release -d 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=640x480
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY="true"
# Uncomment to get a beep at grub start
#GRUB_INIT_TUNE="480 440 1"
boot
So go back to 'grub' and change the number of GRUB_HIDDEN_TIMEOUT to 1, change the value of the line right below it to false, then change GRUB_TIMEOUT's value to 1. After that it will look like this:
GRUB_DEFAULT=0
GRUB_HIDDEN_TIMEOUT=1
GRUB_HIDDEN_TIMEOUT_QUIET=false
GRUB_TIMEOUT=1
(if you are unable to save the file, then press Alt + F2 and type gksu gedit and open the file from there.
Save and close the file, press Ctrl + Alt + T, then run the command:
sudo update-grub
And, when its finished, restart your computer, and see what has changed!
Hope you liked it! ;)
