-1
How to get a precompiled package of any software, so I can install it directly? Because I am a beginner linux user and I am facing problems in compiling any software.
There are several very safe ways to install precompiled software. Points 1-4 detail usage from the standard Ubuntu Repositories while points 5-6 show how to utilise external precompiled packages:
  1. You can install directly from your browser if apturl is setup on your computer. This will install a package from the Ubuntu Repository using a browser link
  2. You can install from the Ubuntu Software Center, this is the standard method of adding precompiled packages
  3. You can use Synaptic which is a graphical manager for apt. This could be considered a slightly more complex application to use than the Software Center
  4. You can use text-based methods via a Terminal screen utilizing either aptitude or apt-get. Again these are considered more 'advanced' techniques than the Software Center and accomplish the same outcome.
  5. You can install downloaded 'deb' packages from carefully selected sources away from the Ubuntu Repositories using either the graphical manager gdebi or the commandline dpkg.
  6. You can add a Personal Package Archive (PPA) to your system and this will often fill any gaps in required applications or even more up to date applications than can be found in the Ubuntu Repositories
There are a few more options for installing precompiled software (see the link in the References below) but these are the basics. If these methods do not give you the package or correct version of that package then it might be time to look at compiling...
References:
andrew.46
  • 39,359
