I'm sorry to bother about this silly question, I found many and many answers on this topic but none of them work for me.
The Ubuntu 14.04 server's got both Openvpn and Samba. The client is a Windows 7 machine.
I'm building a new server to replace an old one (ubuntu 12). The configuration of the new is exactly the same as the old.
Windows 7 can connect to Openvpn and can ping it.
The server sees a connected client ( cat /etc/openvpn/openvpn-status.log ) but can not ping it (don't really know why and I don't know if this could be a problem but I do not think so because the same is on the old server).
smb.conf:
[global]
server string = %h server (Samba, Ubuntu)
map to guest = Bad User
obey pam restrictions = Yes
pam password change = Yes
passwd program = /usr/bin/passwd %u
passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
unix password sync = Yes
syslog = 0
log file = /var/log/samba/log.%m
max log size = 1000
deadtime = 45
socket options = TCP_NODELAY IPTOS_THROUGHPUT
dns proxy = No
usershare allow guests = Yes
panic action = /usr/share/samba/panic-action %d
idmap config * : range =
idmap config * : backend = tdb
map acl inherit = Yes
csc policy = documents
interfaces = 10.8.0.0/24 tun0
hosts allow = 10.8.0.0/24
Server's tun0 is 10.8.0.1 Windows 7 "TAP-Windows Adapter V9" is 10.8.0.6
And I try to connect to the share using \\10.8.0.1
No, without shared folder like \\10.8.0.1\shared because if you create a Windows shortcut you don't necessary need a share name.
It will simply ask for credentials once, connected through vpn, you double click on it.
(Method tested on old server)
The only open ports using UFW are for ssh and openvpn 1194/udp.
Useless to say that with the same configuration, I can connect to the old server and open the share while in the new server I just can't.
This is an example of one of the shares:
[User44]
path = /home/samba/user44
valid users = @user44
force group = user44
read only = No
security mask = 0770
directory mask = 0770
write cache size = 2621440
veto oplock files = /*.tmp/
If there is need of more information I'll be glad to provide them. I think that these are the ones one would promptly be asking for.
Thanks folks,
