10
Since an Ubuntu machine needs an smb client to access a smb server, it would have to establish a connection to the server.
What ports does the client open to establish the connection?
Do those ports continue to listen for incoming connections once the connection to the smb server ends?
Note: I am asking about the ports used by a smb client, not a smb server.
Raffat
  • 309
This is from https://wiki.samba.org/index.php/Samba_Port_Usage
Identify on which ports and interfaces Samba is listening
You can use netstat to identify which ports Samba and related daemons are listening on and on which IPs:
# netstat -tulpn | egrep "samba|smbd|nmbd|winbind" The following is a snippet of an example output:
tcp        0      0 127.0.0.1:139               0.0.0.0:*              LISTEN      43270/smbd           tcp        0      0 10.0.0.1:139
0.0.0.0:*                   LISTEN      43270/smbd           tcp        0      0 10.0.0.1:88                 0.0.0.0:*
LISTEN 43273/samba tcp 0 0 127.0.0.1:88
0.0.0.0:* LISTEN 43273/samba tcp 0 0 127.0.0.1:445 0.0.0.0:*
LISTEN 43270/smbd tcp 0 0 10.0.0.1:445
The above example shows, that the services are listening on localhost (127.0.0.1) and the interface with IP 10.0.0.1 - each on the listed ports (139, 88, 445,...).
Port usage when Samba runs as an Active Directory Domain Controller
Service   Port    protocol
DNS   53  tcp/udp
Kerberos  88  tcp/udp
End Point Mapper (DCE/RPC Locator Service)    135 tcp
NetBIOS Name Service  137 udp
NetBIOS Datagram  138 udp
NetBIOS Session   139 tcp
LDAP  389 tcp/udp
SMB over TCP  445 tcp
Kerberos kpasswd  464 tcp/udp
LDAPS (only if "tls enabled = yes")   636 tcp
Dynamic RPC Ports*    1024-5000   tcp
Global Cataloge   3268    tcp
Global Cataloge SSL (only if "tls enabled = yes") 3269    tcp
Multicast DNS 5353    tcp/udp
  • Samba, like Windows, supports dynamic RPC services. The range starts at 1024. If something occupies this port for some reason, it will be a different port (literally walked up from 1024). Remember, that there can be other ports too, which are related to your Samba installation but not provided from Samba itself, like if you run a NTP server for time synchronisation as well.
Port usage when Samba runs as an NT4 Primary Domain Controller
Port usage when Samba runs as a Member Server
Kulfy
  • 18,154
Daniel
  • 3,626
  • 24
  • 46
