English is my second language so it's not so good, sorry
My laptop runs cpu i5-6300hq and gtx 960M video card. I recently have installed ubuntu in nomodeset because kernel verson 4.2 didn’t support skylate processor (intel hd 530). Therefore, I had to update to kernel 4.4.3 in order to use intel hd 530 for my second monitor. Everything seemed normal, but there is one problem which is after using my latop for a while, ubuntu stops responding, my mouse and keyboard stop working as well so I have to use the power button to restart the laptop; however, the sound works normally (like music). I have tried reinstalling for many times but it was strange one time that I after I had installed in nomodeset and booted to Ubuntu (kernel version 4.2), Ubuntu automatically detected cpu và intel hd 530, and it happened only once. I don’t understand what is happening with kernel of Ubuntu. I am newbie, please help me to fix it.
Ashu
  • 4,004
You should upgrade to Linux kernel 4.3 or 4.4 which has support for Intel skylake and nvidia open source drivers.
After this for nvidia you can try the below steps.
Based on this link nvidia-361 is the driver for Nvidia GTX 960
First uninstall the currently installed NVIDIA drivers. Boot the computer, when the GRUB menu appears ...
Highlight the Ubuntu menu entry and press the E key. Add nouveau.modeset=0 to the end of the linux line. Press F10 to boot the Ubuntu operating system.
When the login screen appears press Ctrl+Alt+F1. Enter your user name and the password, then execute :
sudo apt-get purge nvidia*
sudo reboot
Now install the latest official stable NVIDIA drivers. Boot the computer, when the GRUB menu appears ...
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo apt-get update
sudo apt-get install nvidia-361
sudo reboot
Note : Maybe it is explicitly necessary to select the NVIDIA adapter in BIOS. When you want to use drivers 361, adding the PPA is not necessary. In this case the terminal commands you have to perform are these :
sudo apt-get update
sudo reboot
In case you have installed the nvidia driver from their site then uninstall it as per that instructions.Uninstall that driver by running, as root, sh ./NVIDIA-Linux-x86_64-361.28.run and follow the on screen instructions
Note : The solution I have provide has been tested on Ubuntu 14.04 LTS and Ubuntu 15.10 for two GPUs.
Ashu
  • 4,004
Generally, it's good to have new kernels and microcode when using new processors.
To install kernels from mainline for ubuntu: link
To install intel microcode: Additional drivers > Microcode firmware for intel cpus > apply changes
