Intro
The script bellow uses dbus and on_ac_power shell script (which comes by default with Ubuntu) to poll for presence of an ac adapter and sets brightness according to values set in $HOME/.auto-backlightrc file.
Installation
Installation using git through terminal:
- Run
sudo apt-get install git to install git
- Run
mkdir $HOME/bin. Skip this step if $HOME/bin exists already
cd $HOME/bin
- Run
git clone https://github.com/SergKolo/sergrep.git
- The script will be in
$HOME/bin/sergrep/auto-backlight.sh. Make sure the script is executable with chmod +x $HOME/bin/sergrep/auto-backlight.sh
- Add the script as a startup application. Look for Startup Applications menu in Unity Dash or Gnome search. Alternatively, run
gnome-session-properties command in terminal to launch the menu. Add the full path to script as startup application so that it launches every time you log into GUI.
Alternatively, you can copy and save script source by oneself, chmod +x file, and go through the step #6 described above.
To make the script automatically start every time you log in to Gnome or Unity, use Startup Applications utility.
NOTE: if you want the script to always set AC brightness as well uncomment the else statement on lines 60 and 61 , specifically this part
# The two lines bellow are optional for
# setting brightness if on AC. remove #
# if you want to use these two
# else
# change_brightness $INCREASE
Script source
#!/usr/bin/env bash
# Author: Serg Kolo , contact: 1047481448@qq.com
# Date: February 26 2016
# Purpose: Brightness control that polls for
# ac adapter presence. Uses
# Dependencies: on_ac_power script, dbus, Unity/Gnome
# Written for: https://askubuntu.com/q/739617/295286
# Tested on: Ubuntu 14.04 LTS
# Copyright: Serg Kolo , 2016
# Permission to use, copy, modify, and distribute this software is hereby granted
# without fee, provided that the copyright notice above and this permission statement
# appear in all copies.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
# uncomment the line bellow for debugging
#set -x
ARGV0="$0"
ARGC=$#
main()
# defaults
local DISPLAY=:0
local DECREASE=30
local INCREASE=75
local RCFILE="$HOME/.auto-backlightrc"
# Check the settings
if [ -f $RCFILE ]
then
source $RCFILE
else
create_rcfile $DECREASE $INCREASE
fi
# now actually test if we're using ac adapter
if ! on_ac_power
then
change_brightness $DECREASE
# else
fi
change_brightness()
dbus-send --session --print-reply\
--dest=org.gnome.SettingsDaemon.Power\
/org/gnome/SettingsDaemon/Power \
org.gnome.SettingsDaemon.Power.Screen.SetPercentage uint32:"$1"
create_rcfile()
echo "DECREASE="$1 > "$RCFILE"
echo "INCREASE="$2 >> "$RCFILE"
while true
do
main
sleep 0.25
done
