I am trying to make Ubuntu run in text mode only as I want to use it as local server. I searched and found that I should edit /etc/default/grub and replace quiet splash with text then run update-grub, but nothing happens. Any suggestions?
Asked
Active
Viewed 8,324 times
Knowledge Cube
- 14,911
So, simply run the following in your terminal
echo 'manual' | sudo tee /etc/init/lightdm.override
sudo update-grub
Ref. to the following topic, Ubuntu 11.10 is using lightdm not gdm :
Jorge Castro
- 73,717
