I have Ubuntu loaded on my sda partition, Mint on my sdd. Ubuntu's Grub isn't seeing that Mint is installed, so I can't boot it. How do I fix Grub so I can boot into either one?
What is the correct way to dual boot ubuntu & mint?
Using a live Ubuntu cd And running boot-repair should fix the issue.
After you have loaded the live cd in "try mode".
open a terminal (ctl alt t) Then run the following command one by one to install the boot repair. Add boot-repair to the repository
sudo add-apt-repository ppa:yannubuntu/boot-repair
Update the package
sudo apt-get update
Next install boot-repair
sudo apt-get install -y boot-repair
Upgarde and run.
sudo apt-get upgrade && boot-repair
Or select it by System->Aministration->Boot Repair.
