I have ArchLinux installed with NON-UEFI (since last edit its UEFI now) on /dev/sda4 partitioned with LVM2 containing two logical volumes (/vgarch/arch_root & /vgarch/arch_home) , since i have GRUB2 installed by Ubuntu 22.04 i want to configure it to detect ArchLinux,mounting /dev/vgarch/arch_root and running update-grub (else os-prob won't detect idk why) gave me the following output
$ sudo update-grub
[sudo] password for ya22y:
Sourcing file `/etc/default/grub'
Sourcing file `/etc/default/grub.d/init-select.cfg'
Generating grub configuration file ...
Found linux image: /boot/vmlinuz-6.2.0-33-generic
Found initrd image: /boot/initrd.img-6.2.0-33-generic
Found linux image: /boot/vmlinuz-6.2.0-26-generic
Found initrd image: /boot/initrd.img-6.2.0-26-generic
Memtest86+ needs a 16-bit boot, that is not available on EFI, exiting
Warning: os-prober will be executed to detect other bootable partitions.
Its output will be used to detect bootable binaries on them and create new boot entries.
/usr/sbin/grub-probe: error: unknown filesystem.
Found Arch Linux on /dev/mapper/vgarch-arch_root
Adding boot menu entry for UEFI Firmware Settings ...
done
GRUB shows ArchLinux entry but when i boot i got error saying
error: file "/vmlinuz-linux-lts" not found
However the kernel is installed. ( and tried to reinstall it from live environment)
$ sudo mount /dev/vgarch/arch_root /mnt
$ sudo chroot /mnt
[root@IYB /]# ls /boot
initramfs-linux-lts-fallback.img  initramfs-linux-lts.img  vmlinuz-linux-lts
Tried to add ArchLinux entry manually by adding the following script to /etc/grub.d/40_custom
menuentry 'Arch Linux' {
                                          #UUID of /dev/vgarch/arch_root partition
        search --no-floppy --fs-uuid --set=root 394db06d-01e3-43a3-bf84-22f7bca2cc0c
        linux /boot/vmlinuz-linux-lts root=UUID=394db06d-01e3-43a3-bf84-22f7bca2cc0c rw
        initrd /boot/initramfs.linux-lts.img }
booting to 'Arch Linux' gave the following:
error: uknown filesystem
Additional details
/dev/sda
Disk /dev/sda: 238,47 GiB, 256060514304 bytes, 500118192 sectors
Disk model: LITEON LMH-256V2
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 7B055726-9B69-4E1B-9DD6-4762B556617D
Device Start End Sectors Size Type /dev/sda1 2048 4095 2048 1M BIOS boot /dev/sda2 4096 1054719 1050624 513M EFI System /dev/sda3 1054720 233877503 232822784 111G Linux filesystem /dev/sda4 233877504 500117503 266240000 127G Linux LVM
Logical volumes
$ sudo lvdisplay
  --- Logical volume ---
  LV Path                /dev/vgarch/arch_root
  LV Name                arch_root
  VG Name                vgarch
  LV UUID                yhsMld-G8Zp-h6au-pfZw-k3V1-EkuT-Wgyf5A
  LV Write Access        read/write
  LV Creation host, time archiso, 2023-09-19 23:22:59 +0100
  LV Status              available
  # open                 0
  LV Size                16,00 GiB
  Current LE             4096
  Segments               1
  Allocation             inherit
  Read ahead sectors     auto
  - currently set to     256
  Block device           253:0
--- Logical volume --- LV Path /dev/vgarch/arch_home LV Name arch_home VG Name vgarch LV UUID cwlwYH-FXu4-zU3n-yHsL-DkSo-Gsl8-uRkuLE LV Write Access read/write LV Creation host, time archiso, 2023-09-19 23:24:11 +0100 LV Status available
open 0
LV Size <110,95 GiB Current LE 28403 Segments 1 Allocation inherit Read ahead sectors auto
  • currently set to 256
Block device 253:1
/boot directory in Arch
ya22y@IYB:~$ sudo mount /dev/vgarch/arch_root /mnt
ya22y@IYB:~$ sudo chroot /mnt
Arch directory /etc/mkinitcpio.conf
i've ran mkinitcpio -P after adding lvm2.
HOOKS=(base udev autodetect modconf kms keyboard keymap consolefont block lvm2 filesystems fsck)
EDIT I have installed grub from ArchLinux to ESP partition a.k.a /dev/sda2, and update it using grub-mkconfig. Now i hade two booting options,ubuntu_grub and arch_grub. However none of the grub associatiated with niether ubuntu or arch seems to detect the other OS.(os-prober enabled).
booting from ubuntu_grub.. Ubuntu OS appears and i can boot into it, however going to grub rescue mode and trying to ls (lvm/vgarch-arch_root) results
booting from arch_grub.. its get me directly to grub rescue mode, however try to ls (lvm/vgarch-arch_root) and ls (hd,gpt3) seems to recognize both OS filesystems.
"no known filesystem".
Boot-Repair Boot Info Summary:
============================== Boot Info Summary ===============================
=> Grub2 (v2.00) is installed in the MBR of /dev/sda and looks at sector 2048 of the same hard drive for core.img. core.img is at this location and looks for (,gpt3)/boot/grub. It also embeds following components:
modules
fshelp ext2 part_gpt biosdisk
sda1: __________________________________________________________________________
File system:       BIOS Boot partition
Boot sector type:  Grub2's core.img
Boot sector info:
sda2: __________________________________________________________________________
File system:       vfat
Boot sector type:  FAT32
Boot sector info:  No errors found in the Boot Parameter Block.
Operating System:
Boot files:        /efi/BOOT/fbx64.efi /efi/BOOT/mmx64.efi
                   /efi/grub_arch/grubx64.efi /efi/ubuntu/grubx64.efi
                   /efi/ubuntu/mmx64.efi /efi/ubuntu/shimx64.efi
                   /efi/ubuntu/grub.cfg
sda3: __________________________________________________________________________
File system:       ext4
Boot sector type:  -
Boot sector info:
Operating System:  Ubuntu 22.04.3 LTS
Boot files:        /boot/grub/grub.cfg /etc/fstab /etc/default/grub
                   /boot/grub/i386-pc/core.img
sda4: __________________________________________________________________________
File system:       LVM2_member
Boot sector type:  -
Boot sector info:
sdb: ___________________________________________________________________________
File system:       iso9660
Boot sector type:  Grub2 (v1.99-2.00)
Boot sector info:  Grub2 (v1.99-2.00) is installed in the boot sector of
                   sdb and looks at sector 0 of the same hard drive for
                   core.img, but core.img can not be found at this
                   location.
Mounting failed:   mount: /mnt/BootInfo/FD/sdb: /dev/sdb already mounted or mount point busy.
================================ 2 OS detected =================================
OS#1: Ubuntu 22.04.3 LTS on sda3 OS#2: Arch Linux (rolling) on mapper/vgarch-arch_root
================================ Host/Hardware =================================
CPU architecture: 64-bit Video: Haswell-ULT Integrated Graphics Controller from Intel Corporation Live-session OS is Ubuntu 64-bit (Ubuntu 22.04.3 LTS, jammy, x86_64)
===================================== UEFI =====================================
BIOS/UEFI firmware: A17(65.17) from Dell Inc. The firmware is EFI-compatible, and is set in EFI-mode for this live-session. SecureBoot disabled (confirmed by mokutil). BootCurrent: 000F Timeout: 2 seconds BootOrder: 000C,000A,000B,000D,000E,0001,0000,0002,0009,000F Boot0000* ubuntu HD(2,GPT,b6110742-692a-45ec-9745-393729ff51e2,0x1000,0x100800)/File(\EFI\ubuntu\shimx64.efi) Boot0001* GRUB PciRoot(0x0)/Pci(0x1f,0x2)/Sata(1,65535,0)/HD(2,GPT,b6110742-692a-45ec-9745-393729ff51e2,0x1000,0x100800)/File(\EFI\ubuntu\grubx64.efi) Boot0002* grub_arch HD(2,GPT,b6110742-692a-45ec-9745-393729ff51e2,0x1000,0x100800)/File(\EFI\grub_arch\grubx64.efi) Boot0009* UEFI: LITEON LMH-256V2M-11 MSATA 256GB PciRoot(0x0)/Pci(0x1f,0x2)/Sata(1,65535,0)/HD(2,GPT,b6110742-692a-45ec-9745-393729ff51e2,0x1000,0x100800)AMBO Boot000A* Diskette Drive BBS(Floppy,Diskette Drive,0x0)AMBO Boot000B* Internal HDD BBS(HD,P1: LITEON LMH-256V2M-11 MSATA,0x0)AMBO Boot000C* USB Storage Device BBS(USB,ADATA USB Flash Drive 0.00,0x0)AMBO Boot000D* CD/DVD/CD-RW Drive BBS(CDROM,CD/DVD/CD-RW Drive,0x0)AMBO Boot000E* Onboard NIC BBS(Network,IBA GE Slot 00C8 v1550,0x0)AMBO Boot000F* UEFI: ADATA USB Flash Drive 0.00 PciRoot(0x0)/Pci(0x14,0x0)/USB(2,0)/HD(2,GPT,f45e2fa1-c5a6-4d79-876d-c8245af921e0,0x95f864,0x2754)AMBO
a9c517741ac31962d7feb152948ad1ee sda2/BOOT/fbx64.efi a660182adef313615746a665966d2ccc sda2/BOOT/mmx64.efi 3ef1fbaf89bb4141a06ee06b1db9ca8f sda2/grub_arch/grubx64.efi 5ddf997e8b025bfbc2009e85b32f60dc sda2/ubuntu/grubx64.efi a660182adef313615746a665966d2ccc sda2/ubuntu/mmx64.efi 64349b3622c65f495a99dbf6102496e3 sda2/ubuntu/shimx64.efi 64349b3622c65f495a99dbf6102496e3 sda2/BOOT/BOOTX64.efi
============================= Drive/Partition Info =============================
Disks info: ____________________________________________________________________
sda : is-GPT, hasBIOSboot, has---ESP, not-usb, not-mmc, has-os, no-wind, 2048 sectors * 512 bytes
Partitions info (1/3): _________________________________________________________
mapper/vgarch-arch_root : is-os, 64, pacman, no-docgrub, grub2, grub-install, grubenv-ok, grub-mkconfig -o /boot/grub, not-far mapper/vgarch-arch_home : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, not-far sda2 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, not-far sda3 : is-os, 64, apt-get, signed grub-pc grub-efi , grub2, grub-install, grubenv-ok, update-grub, farbios
Partitions info (2/3): _________________________________________________________
mapper/vgarch-arch_root : isnotESP, fstab-without-efi, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot mapper/vgarch-arch_home : isnotESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot sda2 : is---ESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot sda3 : isnotESP, fstab-has-goodEFI, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot
Partitions info (3/3): _________________________________________________________
mapper/vgarch-arch_root : not--sepboot, with-boot, fstab-without-boot, not-sep-usr, with--usr, fstab-without-usr, std-grub.d, sda mapper/vgarch-arch_home : maybesepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, sda sda2 : not--sepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, sda sda3 : not--sepboot, with-boot, fstab-without-boot, not-sep-usr, with--usr, fstab-without-usr, std-grub.d, sda
fdisk -l (filtered): ___________________________________________________________
Disk sda: 238.47 GiB, 256060514304 bytes, 500118192 sectors Disk identifier: 7B055726-9B69-4E1B-9DD6-4762B556617D Start End Sectors Size Type sda1 2048 4095 2048 1M BIOS boot sda2 4096 1054719 1050624 513M EFI System sda3 1054720 233877503 232822784 111G Linux filesystem sda4 233877504 500117503 266240000 127G Linux LVM Disk mapper/vgarch-arch_root: 16 GiB, 17179869184 bytes, 33554432 sectors Disk mapper/vgarch-arch_home: 110.95 GiB, 119130816512 bytes, 232677376 sectors Disk sdb: 7.24 GiB, 7775191040 bytes, 15185920 sectors Disk identifier: F45E2FA1-C5A6-4D79-876F-C8245AF921E0 Start End Sectors Size Type sdb1 64 9828451 9828388 4.7G Microsoft basic data sdb2 9828452 9838519 10068 4.9M EFI System sdb3 9838520 9839119 600 300K Microsoft basic data sdb4 9842688 15185856 5343169 2.5G Linux filesystem
parted -lm (filtered): _________________________________________________________
sda:256GB:scsi:512:512:gpt:ATA LITEON LMH-256V2:; 1:1049kB:2097kB:1049kB:::bios_grub; 2:2097kB:540MB:538MB:fat32:EFI System Partition:boot, esp; 3:540MB:120GB:119GB:ext4::; 4:120GB:256GB:136GB:::lvm; sdb:7775MB:scsi:512:512:gpt:ADATA USB Flash Drive:; 1:32.8kB:5032MB:5032MB::ISO9660:hidden, msftdata; 2:5032MB:5037MB:5155kB::Appended2:boot, esp; 3:5037MB:5038MB:307kB::Gap1:hidden, msftdata; 4:5039MB:7775MB:2736MB:ext4::; mapper/vgarch-arch_home:119GB:dm:512:512:loop:Linux device-mapper (linear):; 1:0.00B:119GB:119GB:ext4::; mapper/vgarch-arch_root:17.2GB:dm:512:512:loop:Linux device-mapper (linear):; 1:0.00B:17.2GB:17.2GB:ext4::;
blkid (filtered): ______________________________________________________________
NAME FSTYPE UUID PARTUUID LABEL PARTLABEL sda
├─sda1 0b56d3c5-5f49-4918-b03e-a74ac1b4a646
├─sda2 vfat BD1A-71EF b6110742-692a-45ec-9745-393729ff51e2 EFI System Partition ├─sda3 ext4 e5d44bf3-db5f-40ff-bd31-ca7c932bc706 617bf50b-b498-48b2-857d-9537226c4a72
└─sda4 LVM2_member JWq8ac-3jR4-Ey1E-2mw0-EmPJ-YPVe-dPVeR8 763ae511-8ba2-400a-8cca-0e4126bfa1a0
├─vgarch-arch_root ext4 394db06d-01e3-43a3-bf84-22f7bca2cc0c
└─vgarch-arch_home ext4 12ca58df-3d30-436e-95ff-cc4c42c6e7a2
sdb iso9660 2023-08-08-01-19-05-00 Ubuntu 22.04.3 LTS amd64 ├─sdb1 iso9660 2023-08-08-01-19-05-00 f45e2fa1-c5a6-4d79-876e-c8245af921e0 Ubuntu 22.04.3 LTS amd64 ISO9660 ├─sdb2 vfat F7DB-4D56 f45e2fa1-c5a6-4d79-876d-c8245af921e0 ESP Appended2 ├─sdb3 f45e2fa1-c5a6-4d79-876c-c8245af921e0 Gap1 └─sdb4 ext4 913a515f-213d-4b90-954b-51e9103431ed 424ba32d-f6fd-a74e-87e0-cb7c55af8ef6 writable
Mount points (filtered): _______________________________________________________
                                                           Avail Use% Mounted on
/dev/disk/by-label/writable[/install-logs-2023-09-23.0/crash] 2.3G 0% /var/crash /dev/disk/by-label/writable[/install-logs-2023-09-23.0/log] 2.3G 0% /var/log /dev/mapper/vgarch-arch_home 103.1G 0% /mnt/boot-sav/mapper/vgarch-arch_home /dev/mapper/vgarch-arch_root 12.7G 14% /mnt/boot-sav/mapper/vgarch-arch_root /dev/sda2 505.7M 1% /mnt/boot-sav/sda2 /dev/sda3 84.5G 17% /mnt/boot-sav/sda3 /dev/sdb1 0 100% /cdrom
Mount options (filtered): ______________________________________________________
============================== ls -R /dev/mapper/ ==============================
/dev/mapper: control vgarch-arch_home vgarch-arch_root
===================== sda2/efi/ubuntu/grub.cfg (filtered) ======================
search.fs_uuid e5d44bf3-db5f-40ff-bd31-ca7c932bc706 root hd0,gpt3 set prefix=($root)'/boot/grub' configfile $prefix/grub.cfg
====================== sda3/boot/grub/grub.cfg (filtered) ======================
Ubuntu e5d44bf3-db5f-40ff-bd31-ca7c932bc706 Ubuntu, with Linux 6.2.0-33-generic e5d44bf3-db5f-40ff-bd31-ca7c932bc706 Ubuntu, with Linux 6.2.0-26-generic e5d44bf3-db5f-40ff-bd31-ca7c932bc706
END /etc/grub.d/30_os-prober
UEFI Firmware Settings uefi-firmware
END /etc/grub.d/30_uefi-firmware
Arch Linux
========================== sda3/etc/fstab (filtered) ===========================
<file system> <mount point> <type> <options> <dump> <pass>
/ was on /dev/sda3 during installation
UUID=e5d44bf3-db5f-40ff-bd31-ca7c932bc706 / ext4 errors=remount-ro 0 1
/boot/efi was on /dev/sda2 during installation
UUID=BD1A-71EF /boot/efi vfat umask=0077 0 1 /swapfile none swap sw 0 0
======================= sda3/etc/default/grub (filtered) =======================
GRUB_DEFAULT="0" GRUB_TIMEOUT_STYLE="hidden" GRUB_TIMEOUT="10" GRUB_DISTRIBUTOR="lsb_release -i -s 2&gt; /dev/null || echo Debian" GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" GRUB_CMDLINE_LINUX="" GRUB_SAVEDEFAULT="false" GRUB_DISABLE_OS_PROBER="false"
==================== sda3: Location of files loaded by Grub ====================
       GiB - GB             File                                 Fragment(s)
78.407356262 = 84.189257728 boot/grub/grub.cfg 1 2.705089569 = 2.904567808 boot/grub/i386-pc/core.img 1 9.759067535 = 10.478718976 boot/vmlinuz 2 10.729740143 = 11.520970752 boot/vmlinuz-6.2.0-26-generic 1 9.759067535 = 10.478718976 boot/vmlinuz-6.2.0-33-generic 2 10.729740143 = 11.520970752 boot/vmlinuz.old 1 15.446777344 = 16.585850880 boot/initrd.img 1 4.538490295 = 4.873166848 boot/initrd.img-6.2.0-26-generic 2 15.446777344 = 16.585850880 boot/initrd.img-6.2.0-33-generic 1 4.538490295 = 4.873166848 boot/initrd.img.old 2
===================== sda3: ls -l /etc/grub.d/ (filtered) ======================
-rwxr-xr-x 1 root root 18683 Dec 18 2022 10_linux -rwxr-xr-x 1 root root 43031 Dec 18 2022 10_linux_zfs -rwxr-xr-x 1 root root 14387 Dec 18 2022 20_linux_xen -rwxr-xr-x 1 root root 13369 Dec 18 2022 30_os-prober -rwxr-xr-x 1 root root 1372 Dec 18 2022 30_uefi-firmware -rwxr-xr-x 1 root root 700 May 17 05:35 35_fwupd -rwxr-xr-x 1 root root 467 Sep 20 18:47 40_custom -rwxr-xr-x 1 root root 215 Dec 18 2022 41_custom drwxr-xr-x 4 root root 4096 Sep 19 23:23 backup
========================== sda3/etc/grub.d/40_custom ===========================
#!/bin/sh exec tail -n +3 $0
This file provides an easy way to add custom menu entries. Simply type the
menu entries you want to add after this comment. Be careful not to change
the 'exec tail' line above
menuentry 'Arch Linux' { insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 394db06d-01e3-43a3-bf84-22f7bca2cc0c linux /boot/vmlinuz-linux-lts root=UUID=394db06d-01e3-43a3-bf84-22f7bca2cc0c rw initrd /boot/initramfs.linux-lts.img }
==================== blkid (filtered) before lvm activation ====================
/dev/mapper/vgarch-arch_root: UUID="394db06d-01e3-43a3-bf84-22f7bca2cc0c" BLOCK_SIZE="4096" TYPE="ext4" /dev/mapper/vgarch-arch_home: UUID="12ca58df-3d30-436e-95ff-cc4c42c6e7a2" BLOCK_SIZE="4096" TYPE="ext4" /dev/sda2: UUID="BD1A-71EF" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="EFI System Partition" PARTUUID="b6110742-692a-45ec-9745-393729ff51e2" /dev/sda3: UUID="e5d44bf3-db5f-40ff-bd31-ca7c932bc706" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="617bf50b-b498-48b2-857d-9537226c4a72" /dev/sdb1: BLOCK_SIZE="2048" UUID="2023-08-08-01-19-05-00" LABEL="Ubuntu 22.04.3 LTS amd64" TYPE="iso9660" PARTLABEL="ISO9660" PARTUUID="f45e2fa1-c5a6-4d79-876e-c8245af921e0" /dev/sdb4: LABEL="writable" UUID="913a515f-213d-4b90-954b-51e9103431ed" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="424ba32d-f6fd-a74e-87e0-cb7c55af8ef6" /dev/sdb2: SEC_TYPE="msdos" LABEL_FATBOOT="ESP" LABEL="ESP" UUID="F7DB-4D56" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="Appended2" PARTUUID="f45e2fa1-c5a6-4d79-876d-c8245af921e0" /dev/sda4: UUID="JWq8ac-3jR4-Ey1E-2mw0-EmPJ-YPVe-dPVeR8" TYPE="LVM2_member" PARTUUID="763ae511-8ba2-400a-8cca-0e4126bfa1a0" /dev/sdb3: PARTLABEL="Gap1" PARTUUID="f45e2fa1-c5a6-4d79-876c-c8245af921e0" /dev/sda1: PARTUUID="0b56d3c5-5f49-4918-b03e-a74ac1b4a646"
================================ LVM activation ================================
modprobe dm-mod
vgscan --mknodes Found volume group "vgarch" using metadata type lvm2 vgchange -ay 2 logical volume(s) in volume group "vgarch" now active lvscan ACTIVE '/dev/vgarch/arch_root' [16.00 GiB] inherit ACTIVE '/dev/vgarch/arch_home' [<110.95 GiB] inherit blkid -g
Suggested repair: ______________________________________________________________
The default repair of the Boot-Repair utility would purge (in order to fix packages) and reinstall the grub-efi of mapper/vgarch-arch_root, using the following options: sda2/boot/efi Additional repair would be performed: unhide-bootmenu-10s use-standard-efi-file
Final advice in case of suggested repair: ______________________________________
Please do not forget to make your UEFI firmware boot on the Arch Linux (rolling) entry (sda2/efi/**/grub.efi (** will be updated in the final message) file) !
karel
  • 122,292
  • 133
  • 301
  • 332
ya22y
  • 33
Apparently running os-prober from arch side detected ubuntu, here's how to do it:
-Boot to Arch Linux from a live cd and connect to the network. using iwctl
-Mount partition of logical volume containing root system /dev/vgarch/arch_root in my case.
$mount /dev/vgarch/arch_root /mnt
-chroot to the mounted partition $arch-chroot /mnt
-install grub package on the system using pacman -S grub dosfstools os-prober mtools
-now mount ESP partition to /boot/EFI directory (create one if doesn't exist using mkdir /boot/EFI)
$mount /dev/sda2 /boot/EFI
-install grub on EFI partition
rub-install --target=x86_64-efi --efi-directory=/boot/EFI --bootloader-id=ARCH --recheck -make sure os-prober is enabled and update grub
grub-mkconfig -o /boot/grub/grub.cfg
-exit chroot and reboot, then boot from ARCH entry, the new installed grub will detect ubuntu os and you can make it your default bootloader from boot sequence priority.
ya22y
  • 33
