I tried to disable my touchscreen for Ubuntu 15.10 using the first answer in this link:
How do I disable the touchscreen drivers?
However, on reboot the OS crashes. I'm pretty sure I just need to delete the 'Ignore "on"' line in the file I edited, but am not sure how to access it (dual boot in Windows right now).
Rdesmond
  • 103
If the crash happens after the terminal sessions are set up you can also do a "control" "alt" "f1" and if it shows a login use your normal account to log into a terminal session.
Otherwise you can also do this from the option "try ubuntu" from a live DVD session. In the launcher you will have all your disks, mount the one that holds your OS by clicking it. Editing is probably best done by going to a terminal session and using "sudo" as you normally would edit the file.
Rinzwind
  • 309,379
