I've just self-build a beefy new desktop, with a Gigabyte Z97P-D3 mobo, intel i7-4790K, 16GB RAM. I am using the on-board sound hardware intel HDA (Realtek ALC887-VD) for audio output. I'm running Ubuntu 14.04 LTS.
Every few minutes I can hear a short skip in audio playing, almost as though one frame is being dropped. It's incredibly annoying and happens regardless of the source (VLC / Spotify / Chromium browser). In the brief moment during a skip, the Sound Preferences > Output tab's list of devices gets greyed out, and the volume control indicator briefly flashes as though it is muted, before all flicking back to normal.
ALSAmixer also similarly glitches during the skips with the volume bars all disappearing for a fraction of a second.
I've tried the following workarounds (none of which work for me):
1) /etc/modprobe.d/alsa-base.conf: Position_fix setting
options snd-hda-intel model=generic position_fix=1
2) PulseAudio /etc/pulse/default.pa: Turning off tsched
load-module module-udev-detect use_ucm=0 tsched=0
3) PulseAudio /etc/pulse/default.pa: Adjusting defaults (all sorts of combinations and values of the below)
default-fragments = 2
default-fragment-size-msec = 250
default-sample-rate = 48000
realtime-scheduling = yes
realtime-priority = 5
4) Reinstalling PulseAudio
5) Upgrading the kernel to the latest stable (4.4.2)
6) Using Jack2 instead of PulseAudio
7) Buying a new sound card (SoundBlaster Live), which doesn't seem to work with various applications like Spotify.
Output of cat /proc/asound/card*/codec* | grep Codec:
Codec: Intel Generic
Codec: Realtek ALC887-VD
Codec: Nvidia GPU 60 HDMI/DP
0 [HDMI ]: HDA-Intel - HDA Intel HDMI HDA Intel HDMI at 0xf7914000 irq 33
1 [PCH ]: HDA-Intel - HDA Intel PCH HDA Intel PCH at 0xf7910000 irq 32
2 [NVidia ]: HDA-Intel - HDA NVidia HDA NVidia at 0xf7080000 irq 17
It's card #1 that I'm using.
Output of uname -a:
Linux alnitak 4.4.2-040402-generic #201602171633 SMP Wed Feb 17 21:35:10 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
I suspect this has something to do with the intel HDA drivers seeing as Pulse, ALSA and Jack are all affected.
Are there any fixes I'm missing?
