I had a mainline kernel 4.2.5 and based on the advise that i should not have a baseline kernel as in this thread I installed it via this command
sudo apt-get install --install-recommends linux-generic-lts-wily xserver-xorg-core-lts-wily xserver-xorg-lts-wily xserver-xorg-video-all-lts-wily xserver-xorg-input-all-lts-wily libwayland-egl1-mesa-lts-wily
but after that i keep on getting black screen. I thought it's because of my nvidia driver so i referred my earlier thread
and then executed
sudo apt-get purge nvidia*
sudo reboot
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo apt-get update
sudo apt-get install nvidia-361 nvidia-prime
sudo reboot
But i am still having black screen. Even if i do
Highlight the Ubuntu menu entry and press the E key. Add nouveau.modeset=0 to the end of the linux line. Press F10 to boot the Ubuntu operating system
I get black screen only.
Had a chat with Pilot6 execute this command
sudo apt-get install linux-generic-lts-wily xserver-xorg-lts-wily libgl1-mesa-glx-lts-wily libglapi-mesa-lts-wily libgl1-mesa-glx-lts-wily:i386 libglapi-mesa-lts-wily:i386
lspci -k | grep -EA2 'VGA|3D'
tells that nvidia kernel is in use
Later i purged nvidia and install it
sudo reboot
sudo apt-get update
sudo apt-get install nvidia-352 nvidia-prime
sudo reboot
But even after that I am having black screen only. I need to login into Recovery mode and then normal boot and then Ctrl+Alt+F1 to do any work.
============================================================================== Very unstable system - it was working for around 10-15 minutes then mouse and keyboard - everything is un responsive.
I curse my self - why i tried to do mess up something which was working alright. Even if that was mainline kernel it was working fine.
Ashu
  • 4,004
That command is wrong in many cases. Maybe it will work on a fresh installed system. But when you have multiarch 32-bit packages, it removes lots of packages. You could see it when you ran the command.
The correct command is
I ran it on two computers today and upgraded without any issues.
Another unlikely problem may be because you have an unsupported Nvidia driver 361. It may be incompatible with the new version of xorg-server.
But as I said, it is very unlikely.
You can fix your system by running
sudo apt-get install ubuntu-desktop
if you are lucky enough.
P.S. And I never advised you to install new xorg-server. I gave you a command to upgrade only the kernel that was
Upgrading HWE graphical stack from vivid to wily is not worth the effort, because it is a very minor version change from 1.17.1 to 1.17.2.
Pilot6
  • 92,041
I can resolve this issue only after doing a clean install of Ubuntu desktop 15.10(not upgrade from 14.04 LTS to 15.10). Had a lot of issues with the 14.04.3 LTS as my wifi was not working and without wifi it is almost impossible to work. Moreover with the mainline kernel being installed and then getting it using standard way further messed up the entire situation. Even when i got the generic kernel 4.2 -i got issues with my nvidia graphics card. Can't devote more than 8 hours on any such things so finally i decided to upgrade to 15.10 and install the required apps. Another reason for doing this upgrade was that it's easy to upgrade to 16.04 LTS once it comes(21st April, 2016). I had backed up all my important data so there was no issue regarding that. Thanks everyone for your help.
Moral of the story - don't fix unless it is broken.
Ashu
  • 4,004
