Is it possible to install Jupyter Notebook through apt-get install? For example, we can install numpy by using apt-get install python-numpy.
Ubuntu 20.04 and later
sudo apt install jupyter-notebook
Ubuntu 18.04-19.10
Open the terminal and type:
sudo apt install python3-notebook jupyter jupyter-core python-ipykernel
To start the notebook server run the following command:
jupyter notebook
You should see Jupyter Notebook open in your web browser.
Ubuntu 17.04 and 17.10
In Ubuntu 17.04 and later Jupyter Notebook is available in the default Ubuntu repositories and can be quickly and easily installed using apt. Open the terminal and type:
sudo apt install jupyter-notebook jupyter-core python-ipykernel
python-ipykernel is necessary for running Python 2.x programs in Jupyter Notebook, which otherwise supports only Python 3.x.
jupyter notebook
Ubuntu 16.04 and earlier
Google Colaboratory is Google's free Jupyter notebook environment that requires no setup and runs entirely in the cloud.
- 122,292
- 133
- 301
- 332
I installed it using
pip install jupyter
(pip3 if Python3 is installed; also, ensure you have root access, i.e. logged in to the terminal as root@...)
and for python dependencies
apt-get install build-essential python3-dev
In ubuntu desktop 14.04.3 LTS. I am on python3.
- 51,797
- 4,004
Install it using
sudo -H pip install jupyter
After installation completes, use the following command
jupyter notebook
- 113
Based on official recommendation here we should use:
python -m pip install jupyter
python3 -m pip install jupyter
After this command and all of the previous I had a problem with permission error. To resolve it we should use next command:
python -m pip install jupyter --user
python3 -m pip install jupyter --user
sudo -H pip3 install jupyter (with pip3, not pip) worked for me after numerous other approaches. I did this on the ubuntu linux with python 3.5.3 built into lavano chromebook c330. Also installed spyder and numerous favorite commands like "locate".
- 119,640
It doesn't appear to be possible using only apt-get.
apt-file find jupyter ## returns no results
For 16.04:
sudo apt-get install python-pip
pip install --upgrade pip ## secret sauce -- pip fails otherwise
sudo pip install jupyter
then
jupyter notebook
Replace 'pip' with 'pip3' for use with Python3.
- 2,906
