I'm trying to install Ubuntu on my laptop since some days. However after it's installed GRUB is never launcher and Windows starts directly with no chance to launch Ubuntu.
I've tried with Windows 7 and the same happened, and now with Windows 10 it's still the same. However I installed it a friend's laptop and there's no problem.
Help me please. I've tried many methods I found on the Internet and still nothing.
Thanks and regards.
Ulises CT
  • 103
  1. Disable Secure boot in BIOS
  2. Disable fastboot and hibernation in Windows
  3. Try boot-repair if that is still not working
 sudo add-apt-repository ppa:yannubuntu/boot-repair
 sudo apt-get update
 sudo apt-get install -y boot-repair && boot-repair
When i used to do boot-repair at the end of pastebin contents it has these lines
> If your computer reboots directly into Windows, try to change the boot
> order in your BIOS. If your BIOS does not allow to change the boot
> order, change the default boot entry of the Windows bootloader. For
> example you can boot into Windows, then type the following command in
> an admin command prompt: **bcdedit /set {bootmgr} path
> \EFI\ubuntu\shimx64.efi**
Try this command bcdedit /set {bootmgr} path \EFI\ubuntu\shimx64.efi The above command works in Windows 8 as well as 10 but this should be the last resort unless your boot-repair options gives you this option only
Ashu
  • 4,004
