Whenever i am trying to run an applet in my Eclipse,it's showing this error.This error was not showing when I tried to run the same program some days before.
Smooth is not supported by this hardware (or driver)
Unfolding Map v0.9.7 (UCSD edition)
Using OpenGLMapDisplay with processing.opengl.PGraphics2D
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00007f4168bcc040, pid=3497,tid=139919047476992
# JRE version: Java(TM) SE Runtime Environment (8.0_72-b15) (build 1.8.0_72-b15)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.72-b15 mixed mode linux-amd64 compressed oops)
# Problematic frame:
# C [i965_dri.so+0x3ca040]
# Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# An error report file with more information is saved as:
# /home/coder/workspace/UCSDUnfoldingMaps/build/hs_err_pid3497.log
Compiled method (nm) 22323 2003 n 0 jogamp.opengl.x11.glx.GLX::dispatch_glXSwapBuffers0 (native)
total in heap [0x00007f417c977f50,0x00007f417c9782a0] = 848
relocation [0x00007f417c978078,0x00007f417c9780c0] = 72
main code [0x00007f417c9780c0,0x00007f417c978298] = 472
oops [0x00007f417c978298,0x00007f417c9782a0] = 8
# If you would like to submit a bug report, please visit:
# http://bugreport.java.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
I tried the solutions given in Eclipse (ADT) crash Failed to write core dump. Core dumps have been disabled discussions but it is of no use.
Another problem I am facing is that I even can't uninstall eclipse.Whenever I am trying to do so using the commands
sudo apt-get autoremove eclipse
or by using the command
sudo apt-get purge eclipse
It says that the package eclipse is not installed so not removed.But I did install Eclipse. So it will be better if anyone could give me the exact way to uninstall eclipse completely for fresh installation.I downloaded the tar.gz file initially and then extracted it for the initial setup of eclipse.
