26
i found my problem here: how to fix “Failed to write core dump. Core dumps have been disabled” error while running java and here: Eclipse crashing on startup and here: Eclipse continue crash
Nothing help me;
This is the problem:
# A fatal error has been detected by the Java Runtime Environment:
#  SIGSEGV (0xb) at pc=0x00007fa434ffc2a1, pid=6989, tid=140346763503360
# JRE version: Java(TM) SE Runtime Environment (7.0_55-b13) (build 1.7.0_55-b13)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (24.55-b03 mixed mode linux-amd64 compressed oops)
# Problematic frame:
# C  [libsoup-2.4.so.1+0x6c2a1]  soup_session_feature_detach+0x11
# Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# If you would like to submit a bug report, please visit:
#   http://bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
I did this: To enable core dumping, try "ulimit -c unlimited" before starting Java again and also not help;
I tried to upgrade, but i had dependency problems.
In the last few days i tried to install Cisco packet Tracer, this mean i install and uninstall some stuff (like ia386 - something - i dont remember the package name).
If i cant fix this, I thinking to do a fresh installation of ADT or over to Intellij.
To do a fresh installation (how i should backup all my plugins?)
Aby
  • 883
To solve this issue, try to put this line (slightly different from -Dorg...)
org.eclipse.swt.browser.DefaultType=mozilla
at the end of this file
eclipse/configuration/config.ini
I had install the last java version "1.8.0_05" and a fresh ADT and the crash disappear, I don't know what produce this, but a good shortcut to this problem is re-install, and finish this.
Aby
  • 883
To solve this issue, put this line:
and it'll work fine !!
Fabby
  • 35,017
