I own a MSI GP62 6QE-260XFR, which is a laptop featuring an i5-6300HQ CPU and a GTX 950M graphics card, sold without OS.
I've installed Windows 10 on a partition. It works just fine. My problem is that I'm unable to run a Linux OS without the acpi=off boot option.
The boot error is the following:
ACPI : EC: Fail in evaluating the _REG object of EC device. Broken bios is suspected.
I've managed to install and run Ubuntu on a partition thanks to this guide (in French) for recent MSI computers. It basically consisted in:
- Disabling CPU C-States in BIOS
- Running an Ubuntu Live USB with the following boot options:
nouveau.blacklist=1 acpi=offbeforequiet splash - Installing Ubuntu
- Running the installed OS with the same boot options
- Updating the system and installing NVIDIA drivers
By then I should have been able to run Ubuntu without acpi=off, but I get the same error message as before. I've installed the latest version of the kernel (4.4.1), hoping it would be more compatible with my PC but the problem is the same.
Thanks to the ACPI being disabled, I can't see battery levels, which makes Ubuntu a bit unusable. Does someone know what I should do?
