So I'm trying to get my Realtek RTL8812AU USB Wireless to work. I came across this package for it: https://github.com/gnab/rtl8812au
I'm about to install it, but it says it's built for x86 and I am running Ubuntu 15.10 x64. I looked for CONFIG_PLATFORM for x64 architecture in the Makefile and I couldn't find any (but, as my name suggests, i'm a newb).
So, I set about trying to install i386 libraries. And this forum: How to run 32-bit app in Ubuntu 64-bit? Told me to do the following:
sudo dpkg --add-architecture i386
sudo apt-get update
sudo apt-get install libc6:i386 libncurses5:i386 libstdc++6:i386
Using aptitude I saw a lot of dependencies and conflicts with these packages... should I be doing this? Are these old packages?
Thank you in advance for your help.
Newwbie
I would simply try to go with the instructions in the Readme file of the github repo...
First... install git
sudo apt-get install git
Clone the repository:
git clone https://github.com/gnab/rtl8812au
cd rtl8812au
compile the module...
make
sudo cp 8812au.ko /lib/modules/$(uname -r)/kernel/drivers/net/wireless
sudo depmod
sudo insmod 8812au.ko
If you get an error, you might need the kernel headers...
sudo apt-get install linux-headers-$(uname -r)
Start again with 'make'...
You don't need the i386 libraries to compile a kernel module.
minimec
  • 846
