13
I have installed:
  • sudo apt-get install ssmtp
  • sudo apt-get install mailutils
When I use command:
echo "something" | mail -s "testing email" email@example.com
The generated email have From field set to something like this:
Is there a config file or something, where I can change this FROM default address?
Note, that changing the TO field is easy, as explained here: How to get ssmtp to map local user to email address for the To: field, but I need to change the default FROM field.
Edit: I also need to change FROM address for sendmail emulation. In my case, the Cron sets FROM: root and TO: root, that I would like to change to normal email address.
Maris B.
  • 453
  • 17
There are a couple of settings in ssmtp that can be manipulated to allow a change in the 'From' field of emails:
  1. There is a setting within /etc/ssmtp/ssmtp.conf. By default the system selects the 'From' address but this can be altered by unchecking the FromLineOverride line:
    # Are users allowed to set their own From: address?
    # YES - Allow the user to specify their own From: address
    # NO - Use the system generated From: address
    #FromLineOverride=YES
    By 'unchecking' I mean remove the hash mark at the beginning of that particular line.
  2. There can be settings within /etc/ssmtp/revaliases to allow a specific 'From' line from each user. The example given in revaliases is reasonably unhelpful:
    # Example: root:your_login@your.domain:mailhub.your.domain[:port]
    # where [:port] is an optional port number that defaults to 25.
    But the man pages gives a much more explicit example:
    A reverse  alias  gives  the From: address placed on a user's outgoing
    messages and (optionally) the  mailhub  these  messages  will  be  sent
    through. Example:
     root:jdoe@isp.com:mail.isp.com
    Messages  root  sends  will be identified as from jdoe@isp.com and sent
    through mail.isp.com.
I personally do not use ssmtp instead I use msmtp where the syntax for altering the 'From' field is a lot simpler and can be contained in the file $HOME/.msmtprc:
from my.email.address@myisp.com
which is a lot easier...
References:
andrew.46
  • 39,359
For an answer using mailutils, see the answer to this previous question. You can configure mailutils like this:
Create a file /etc/mailutils.conf with the following contents:
address {
  email-domain somedomain.com;
SomeoneElse
  • 326
