I have struggled a bit with ssmtp too. The first thing I learned is that the aliases mechanism does not work with the plain mail program; I have to use mailx from the package bsd-mailx — never knew why. So before starting to change configurations around check with it.
Anyway, as a reference, I have a working ssmtp setup like the following:
file /etc/ssmtp/ssmtp.conf:
# Config file for sSMTP sendmail
# The person who gets all mail for userids < 1000
# Make this empty to disable rewriting.
root=romano@mymail.domain.com
# The place where the mail goes. The actual machine name is required no
# MX records are consulted. Commonly mailhosts are named mail.domain.com
mailhub=mymailserver.mymail.domain.com:25
# Where will the mail seem to come from?
rewriteDomain=mymail.domain.com
# The full hostname
hostname=myhostname.mymail.domain.com
# Use SSL/TLS before starting negotiation
UseTLS=No
#UseSTARTTLS=Yes
# Are users allowed to set their own From: address?
# YES - Allow the user to specify their own From: address
# NO - Use the system generated From: address
FromLineOverride=NO
file /etc/ssmtp/revaliases/
# sSMTP aliases
# Format: local_account:outgoing_address:mailhub
# Example: root:your_login@your.domain:mailhub.your.domain[:port]
# where [:port] is an optional port number that defaults to 25.
root:romano@mymail.domain.com
romano:romano@mymail.domain.com
postmaster:romano@mymail.domain.com
and now it works:
[romano:~] % mailx -v root
Subject: test
test
Cc:
[<-] 220 mymailserver.mymail.domain.com ESMTP my mail server
[->] HELO myhostname.mymail.domain.com
[<-] 250 mymailserver.mymail.domain.com
[->] MAIL FROM:<romano@mymail.domain.com>
[<-] 250 2.1.0 Ok
[->] RCPT TO:<romano@mymail.domain.com>
[<-] 250 2.1.5 Ok
[->] DATA
[<-] 354 End data with <CR><LF>.<CR><LF>
[->] Received: by myhostname.mymail.domain.com (sSMTP sendmail emulation); Fri, 03 Jul 2015 13:25:52 +0200
[->] From: "Romano Giannetti" <romano@mymail.domain.com>
[->] Date: Fri, 03 Jul 2015 13:25:52 +0200
[->] To: root
[->] Subject: test
[->] test
[<-] 250 2.0.0 Ok: queued as BF1CB3BC050
[->] QUIT
[<-] 221 2.0.0 Bye
Notice that domains, hostnames etc. are scrambled for privacy here (so there can be typoes).
