I just ran apt dist-upgrade. I had ubuntu 14.04. Things went smoothly, but after reboot I can't get past the login screen. I tried both GDM and lightDM, but running startx from the terminal works.
The only strange things I noticed are:
  1. if I try to reinstall the video driver, I get:
    Reading package lists... Done
    Building dependency tree
     xserver-xorg-video-ati : Depends: xorg-video-abi-15
                              Depends: xserver-xorg-core (>= 2:1.14.99.902)
                              Depends: xserver-xorg-video-glamoregl but it is not going to be installed
    But libcheese is the latest version:
    dpkg -l | grep libcheese
    ii  libcheese-gtk23:amd64   3.10.2-0ubuntu2   amd64
    ii  libcheese7:amd64        3.10.2-0ubuntu2   amd64
  2. uname -a gives me 3.19.0-49-generic #55~14.04.1-Ubuntu, while the welcome screen states Ubuntu 14.04.03 LTS. Why 3 and 1 ??
  3. on boot, I get the following errors:
     compaudit:105: command not found: getent
     compdump:135: command not found: mv
    but my PATH seems correct:
     /home/shitsu/perl5/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
    The same types of errors are present in the .xsession-errors file:
    /usr/sbin/lightdm-session: line 24: mktemp: command not found
    /usr/sbin/lightdm-session: line 29: : No such file or directory
    /usr/sbin/lightdm-session: line 33: cat: command not found
    /usr/sbin/lightdm-session: line 34: truncate: command not found
    /usr/sbin/lightdm-session: line 106: ls: command not found
    /usr/sbin/lightdm-session: line 117: exec: gnome-session: not found
    My /etc/environment file is:
    PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games"
    PATH="/usr/local/texlive/2015/bin/x86_64-linux:$PATH"
Please, any help will be appreciated.
Derlin
  • 303
Ok, silly of me.
The problem was my /etc/environment file. From this thread, I learned that the 2nd line:
was literally interpreted: the $PATH variable is not expanded (as it usually is in a .bashrc file).
Using startx, I had my session opened, so the PATH set in the .zshrc masked the problem.
But I still haven^t figured out the apt dependencies problem though.
Derlin
  • 303
