SOLVED
Had to change the windows system partition type which was flagged as "Swap" for some reason to NTFS system type. I did this by logging into linux and changing it in the partition manager. I rebooted, loaded my windows7 from the GRUB menu and finally was able to load the login screen.
Old Question
So I installed Linux Ubuntu on a separate partition to avoid conflicts with my windows install. I had lots of problems solving the "install alongside" problem. After I finally was able to do this, and rebooting my computer after a successful Linux install, I wasn't able to boot from windows 7.
I tried lots of solutions but none has been able to help me.
Some things that be relevant to mention:
Active operating system was windows 7, with pre-installed windows 8 on it (but not activated). I don't have a CD-reader in my computer.
I have a grub-menu showing windows 7, but upon clicking on it, its stuck on the windows logo. It just stays there loading forever.
I ran bootinfo script; and this are its results:
                  Boot Info Script 0.61      [1 April 2012]
============================= Boot Info Summary: ===============================
 => Grub2 (v1.99) is installed in the MBR of /dev/sda and looks at sector 1 of
    the same hard drive for core.img. core.img is at this location and looks
    in partition 112 for .
sda1: __________________________________________________________________________
    File system:       vfat
    Boot sector type:  Dell Utility: FAT16
    Boot sector info:  No errors found in the Boot Parameter Block.
    Operating System:
    Boot files:        /DELLBIO.BIN /DELLRMK.BIN /COMMAND.COM
sda2: __________________________________________________________________________
    File system:       ntfs
    Boot sector type:  Windows Vista/7: NTFS
    Operating System:
    Boot files:        /bootmgr /Boot/BCD
sda3: __________________________________________________________________________
    File system:       ntfs
    Operating System:  Windows 7
    Boot files:        /ubuntu/winboot/menu.lst /bootmgr /Boot/BCD
                       /Windows/System32/winload.exe /ubuntu/winboot/wubildr
                       /ubuntu/winboot/wubildr.mbr
sda4: __________________________________________________________________________
    File system:       ext4
    Boot sector type:  Grub2 (v1.99)
    Boot sector info:  Grub2 (v1.99) is installed in the boot sector of sda4
                       and looks at sector 950258656 of the same hard drive
    Operating System:  Ubuntu 14.04.3 LTS
    Boot files:        /boot/grub/grub.cfg /etc/fstab
============================ Drive/Partition Info: =============================
Drive: sda _____________________________________________________________________
Disk /dev/sda: 500.1 GB, 500107862016 bytes
255 heads, 63 sectors/track, 60801 cylinders, total 976773168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
Partition  Boot  Start Sector    End Sector  # of Sectors  Id System
/dev/sda1                  63        80,324        80,262  de Dell Utility
/dev/sda2              81,920    24,686,591    24,604,672  27 Hidden NTFS (Recovery Environment)
/dev/sda3    *     24,686,592   945,315,347   920,628,756  82 Linux swap / Solaris
/dev/sda4         945,315,840   976,771,071    31,455,232  83 Linux
"blkid" output: ________________________________________________________________
Device           UUID                                   TYPE       LABEL
/dev/sda1        5450-4444                              vfat       DellUtility
/dev/sda2        D68A2A4B8A2A2887                       ntfs       RECOVERY
/dev/sda3        06EE2C2BEE2C1609                       ntfs       OS
/dev/sda4        43da45a0-e34e-41ce-ae71-5cf02c75de0a   ext4
================================ Mount points: =================================
Device           Mount_Point              Type       Options
/dev/sda4        /                        ext4       (rw,errors=remount-ro)
======================== sda3/ubuntu/winboot/menu.lst: =========================
debug off
hiddenmenu
default 0
timeout 0
fallback 1
title find /ubuntu/disks/boot/grub/menu.lst
    find --set-root --ignore-floppies /ubuntu/disks/boot/grub/menu.lst
    configfile /ubuntu/disks/boot/grub/menu.lst
title find /ubuntu/install/boot/grub/menu.lst
    fallback 2
    find --set-root --ignore-floppies /ubuntu/install/boot/grub/menu.lst
    configfile /ubuntu/install/boot/grub/menu.lst
title find /menu.lst
    fallback 3
    find --set-root --ignore-floppies /menu.lst
    configfile /menu.lst
title find /boot/grub/menu.lst
    fallback 4
    find --set-root --ignore-floppies /boot/grub/menu.lst
    configfile /boot/grub/menu.lst
title find /grub/menu.lst
    fallback 5
    find --set-root --ignore-floppies /grub/menu.lst
    configfile /grub/menu.lst
title commandline
    commandline
title reboot
    reboot
title halt
    halt
=========================== sda4/boot/grub/grub.cfg: ===========================
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
  set have_grubenv=true
  load_env
fi
if [ "${next_entry}" ] ; then
   set default="${next_entry}"
   set next_entry=
   save_env next_entry
   set boot_once=true
else
   set default="0"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
  menuentry_id_option="--id"
else
  menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
  set saved_entry="${prev_saved_entry}"
  save_env saved_entry
  set prev_saved_entry=
  save_env prev_saved_entry
  set boot_once=true
fi
function savedefault {
  if [ -z "${boot_once}" ]; then
    saved_entry="${chosen}"
  fi
function recordfail {
  set recordfail=1
  if [ -n "${have_grubenv}" ]; then if [ -z "${boot_once}" ]; then save_env recordfail; fi; fi
function load_video {
  if [ x$feature_all_video_module = xy ]; then
    insmod all_video
  else
    insmod efi_gop
    insmod efi_uga
    insmod ieee1275_fb
    insmod vbe
    insmod vga
    insmod video_bochs
    insmod video_cirrus
  fi
if [ x$feature_default_font_path = xy ] ; then
   font=unicode
else
insmod part_msdos
insmod ext2
set root='hd0,msdos4'
if [ x$feature_platform_search_hint = xy ]; then
  search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos4 --hint-efi=hd0,msdos4 --hint-baremetal=ahci0,msdos4  43da45a0-e34e-41ce-ae71-5cf02c75de0a
else
  search --no-floppy --fs-uuid --set=root 43da45a0-e34e-41ce-ae71-5cf02c75de0a
fi
    font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
  set gfxmode=auto
  load_video
  insmod gfxterm
  set locale_dir=$prefix/locale
  set lang=en_US
  insmod gettext
fi
terminal_output gfxterm
if [ "${recordfail}" = 1 ] ; then
  set timeout=30
else
  if [ x$feature_timeout_style = xy ] ; then
    set timeout_style=menu
    set timeout=10
  # Fallback normal timeout code in case the timeout_style feature is
  # unavailable.
  else
    set timeout=10
  fi
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/05_debian_theme ###
set menu_color_normal=white/black
set menu_color_highlight=black/light-gray
if background_color 44,0,30,0; then
  clear
fi
### END /etc/grub.d/05_debian_theme ###
### BEGIN /etc/grub.d/10_linux ###
function gfxmode {
    set gfxpayload="${1}"
    if [ "${1}" = "keep" ]; then
        set vt_handoff=vt.handoff=7
    else
        set vt_handoff=
    fi
if [ "${recordfail}" != 1 ]; then
  if [ -e ${prefix}/gfxblacklist.txt ]; then
    if hwmatch ${prefix}/gfxblacklist.txt 3; then
      if [ ${match} = 0 ]; then
        set linux_gfx_mode=keep
      else
        set linux_gfx_mode=text
      fi
    else
    fi
  else
  fi
else
fi
export linux_gfx_mode
menuentry 'Ubuntu' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-43da45a0-e34e-41ce-ae71-5cf02c75de0a' {
    recordfail
    load_video
    gfxmode $linux_gfx_mode
    insmod gzio
    insmod part_msdos
    insmod ext2
    else
    fi
    linux   /boot/vmlinuz-3.16.0-57-generic root=UUID=43da45a0-e34e-41ce-ae71-5cf02c75de0a ro  quiet splash $vt_handoff
    initrd  /boot/initrd.img-3.16.0-57-generic
submenu 'Advanced options for Ubuntu' $menuentry_id_option 'gnulinux-advanced-43da45a0-e34e-41ce-ae71-5cf02c75de0a' {
    menuentry 'Ubuntu, with Linux 3.16.0-57-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-3.16.0-57-generic-advanced-43da45a0-e34e-41ce-ae71-5cf02c75de0a' {
        recordfail
        load_video
        insmod gzio
        insmod part_msdos
        insmod ext2
        else
        fi
        echo    'Loading Linux 3.16.0-57-generic ...'
        echo    'Loading initial ramdisk ...'
    menuentry 'Ubuntu, with Linux 3.16.0-57-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-3.16.0-57-generic-recovery-43da45a0-e34e-41ce-ae71-5cf02c75de0a' {
        recordfail
        load_video
        insmod gzio
        insmod part_msdos
        insmod ext2
        else
        fi
        linux   /boot/vmlinuz-3.16.0-57-generic root=UUID=43da45a0-e34e-41ce-ae71-5cf02c75de0a ro recovery nomodeset
    menuentry 'Ubuntu, with Linux 3.16.0-30-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-3.16.0-30-generic-advanced-43da45a0-e34e-41ce-ae71-5cf02c75de0a' {
        recordfail
        load_video
        insmod gzio
        insmod part_msdos
        insmod ext2
        else
        fi
        echo    'Loading Linux 3.16.0-30-generic ...'
        linux   /boot/vmlinuz-3.16.0-30-generic root=UUID=43da45a0-e34e-41ce-ae71-5cf02c75de0a ro  quiet splash $vt_handoff
        initrd  /boot/initrd.img-3.16.0-30-generic
    menuentry 'Ubuntu, with Linux 3.16.0-30-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-3.16.0-30-generic-recovery-43da45a0-e34e-41ce-ae71-5cf02c75de0a' {
        recordfail
        load_video
        insmod gzio
        insmod part_msdos
        insmod ext2
        else
        fi
        linux   /boot/vmlinuz-3.16.0-30-generic root=UUID=43da45a0-e34e-41ce-ae71-5cf02c75de0a ro recovery nomodeset
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/20_memtest86+ ###
menuentry 'Memory test (memtest86+)' {
    insmod part_msdos
    insmod ext2
    else
    fi
    knetbsd /boot/memtest86+.elf
menuentry 'Memory test (memtest86+, serial console 115200)' {
    insmod part_msdos
    insmod ext2
    else
    fi
    linux16 /boot/memtest86+.bin console=ttyS0,115200n8
### END /etc/grub.d/20_memtest86+ ###
### BEGIN /etc/grub.d/30_os-prober ###
menuentry 'Windows 7 (loader) (on /dev/sda2)' --class windows --class os $menuentry_id_option 'osprober-chain-D68A2A4B8A2A2887' {
    insmod part_msdos
    insmod ntfs
    set root='hd0,msdos2'
      search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos2 --hint-efi=hd0,msdos2 --hint-baremetal=ahci0,msdos2  D68A2A4B8A2A2887
    else
      search --no-floppy --fs-uuid --set=root D68A2A4B8A2A2887
    fi
    parttool ${root} hidden-
    chainloader +1
menuentry 'Windows 7 (loader) (on /dev/sda3)' --class windows --class os $menuentry_id_option 'osprober-chain-06EE2C2BEE2C1609' {
    insmod part_msdos
    insmod ntfs
    set root='hd0,msdos3'
      search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos3 --hint-efi=hd0,msdos3 --hint-baremetal=ahci0,msdos3  06EE2C2BEE2C1609
    else
      search --no-floppy --fs-uuid --set=root 06EE2C2BEE2C1609
    fi
    chainloader +1
if [ "${timeout}" = 0 ]; then
  set timeout=10
fi
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/30_uefi-firmware ###
### END /etc/grub.d/30_uefi-firmware ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries.  Simply type the
# menu entries you want to add after this comment.  Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f  ${config_directory}/custom.cfg ]; then
  source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f  $prefix/custom.cfg ]; then
  source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
=============================== sda4/etc/fstab: ================================
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
# / was on /dev/sda4 during installation
UUID=43da45a0-e34e-41ce-ae71-5cf02c75de0a /               ext4    errors=remount-ro 0       1
=================== sda4: Location of files loaded by Grub: ====================
           GiB - GB             File                                 Fragment(s)
=============================== StdErr Messages: ===============================
cat: /tmp/BootInfo-cGaxV0L8/Tmp_Log: No such file or directory
aze45sq6d
  • 101
I will recommend doing boot-repair
sudo add-apt-repository ppa:yannubuntu/boot-repair
sudo apt-get update
sudo apt-get install -y boot-repair && boot-repair
You can get more information from here: https://help.ubuntu.com/community/Boot-Repair
"Active operating system was windows 7, with pre-installed windows 8 on it (but not activated)." What exactly does this mean? Why can't your first upgrade to Windows 8 or Windows 10- have a recovery disk(usb) and then do a fresh install? As this is a fresh new install you are not loosing much data.
Ashu
  • 4,004
Try to change grub.cfg for Windows 7.
  1. Boot your system to the GRUB menu.
  2. Select (highlight) the GRUB boot menu entry Windows 7 (loader) (on /dev/sda3)
  3. Press e to edit the GRUB boot commands for Windows 7.
Your current boot command should look like:
insmod part_msdos
insmod ntfs
else
fi
chainloader +1
Change it to
insmod part_msdos
insmod ntfs
insmod ntldr
else
fi
ntldr ($root)/bootmgr
  • Add the command insmod ntldr
  • Change the command chainloader +1 to ntldr ($root)/bootmgr
Press F10 to boot using these edited commands.
If this succeeds in loading the Windows 7, then you could make it permanent
  1. Edit the file /etc/grub.d/40_custom and add the second, modified menuentry.
  2. Run the command update-grub to update grub.cfg to include your customized entry.
Gen
  • 933
