Ok so I've been trying to troubleshoot this for a couple of months now but I just reached the end of my capabilities. The basic problem is that my wifi does not connect to my home network (at least not correctly), so I can't get internet access. The wifi router in my home is not the problem cause all my other devices work fine with it. My impression is that Ubuntu is the problem here. One more thing is that, when I set up a wifi internet-sharing connection with my desktop mac (which is connected to the network by ethernet) I can access this shared connection with the notebook, it's rock-solid stable, connects quickly and delivers internet just perfectly fine. So actually, it seems to be a ubuntu specific problem with that specific wifi network.
Some more specifics on the wifi connection to the network: It technically connects to the router, but it usually take very long till the connection is established, and sometimes it fails to connect completely. After the beginning of the connection (if I get it), I sometimes have a very small time window where internet gets delivered, like 20 seconds to half a minute. After that it's gone. Then, sometimes, I get some internet, but the connection is extremely slow and ultimately stops delivering all together again.
My system is an HP notebook with 12GB RAM , core i5 intel, ubuntu 15.10. My wifi hardware is the (apparently not unproblematic) broadcom BCM43141, for which I use the driver ubuntu recommends me to use (broadcom Linux STA wireless driver source, proprietary).
Approaches I have tried so far:
I have read many posts and threads from people who have problems with the wifi hardware that I have. One thing I have tried is installing an older version of the driver. Didn't work out. I have read through many other peoples problems that sound similar to mine but never got to a solution.
I also tried all the config stuff that I know of. I tried dhclient, got a message "RTNETsomething: File exists." So I deleted the dhcp lease file and tried again. New file got created. Problem stays (also after restarting network services etc.). Then I tried it with a static IP instead of DHCP. Wifi was accessed quickly, but still does not deliver internet. Ultimately, I am also suspecting that it would be good to get a new IP from the DHCP, but dhclient always takes ultra long, and when its done, nothing changed and I still have the same IP.
took a look at the DNS config file and the interfaces file, nothing super strange was found. The resolv.conf file had some DNS server I didnt know about in there so I changed it to the same one my other linux distribution uses, since the wifi works without problems on that one.
At this point I dont know what else to do.
Can anybody help me troubleshoot through this?
08:00.0 Network controller [0280]: Broadcom Corporation BCM43142 802.11b/g/n [14e4:4365] (rev 01)
DeviceName: Broadcom BCM43142 802.11bgn 1x1 WiFi Adapter + BT 4.0 combo adapter
Subsystem: Hewlett-Packard Company Device [103c:2230]
Further note: I followed the instructions from "Installing Broadcom Wireless Drivers", but issue remains.
@ Eduardo Cola: Here the output
# dmesg | grep Wireless
[ 12.966209] input: HP Wireless hotkeys as /devices/virtual/input/input9
[ 13.966379] wlan0: Broadcom BCM4365 802.11 Hybrid Wireless Controller 6.30.223.248 (r487574)
#ifconfig
eno1 Link encap:Ethernet HWaddr a0:2b:b8:59:2d:53
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
eno1:avahi Link encap:Ethernet HWaddr a0:2b:b8:59:2d:53
inet addr:169.254.5.250 Bcast:169.254.255.255 Mask:255.255.0.0
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:3177 errors:0 dropped:0 overruns:0 frame:0
TX packets:3177 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:241496 (241.4 KB) TX bytes:241496 (241.4 KB)
wlo1 Link encap:Ethernet HWaddr 14:2d:27:ce:ee:11
inet addr:192.168.11.22 Bcast:192.168.11.255 Mask:255.255.255.0
inet6 addr: fe80::162d:27ff:fece:ee11/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:296 errors:0 dropped:81 overruns:0 frame:787
TX packets:322 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:31547 (31.5 KB) TX bytes:55495 (55.4 KB)
Interrupt:18
# iwconfig
wlo1 IEEE 802.11abg ESSID:"4CE6764F111C_G"
Mode:Managed Frequency:2.462 GHz Access Point: 52:E6:76:4F:11:1C
Bit Rate=52 Mb/s Tx-Power=200 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:off
Link Quality=50/70 Signal level=-60 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
eno1 no wireless extensions.
lo no wireless extensions.
