30
Is there a way to turn off the display (enter power saving mode) using a command?
For example, when the computer is inactive for a specific interval, the screen turns off to conserve energy. Is there a way to manually turn off the screen, yet keep the computer running normally?
This is a notebook, so there's no 'power-off' button on the monitor itself.
Nathan Osman
  • 32,495
7 Answers7
43
I think you are looking for
xset dpms force off
However, you need to make sure that your acpi is enabled. You can check this with
cat /proc/acpi/info
Another option could be
setterm -powersave powerdown
txwikinger
  • 29,406
I'm running Ubuntu Server without X on a 2007 MacBook Pro. The display is sleeping by itself but won't reactivate when a key is pressed on the keyboard. At this point my fix is to use vbetool. Install using apt-get:
sudo apt-get install vbetool
Then use to turn display on via SSH from a different machine:
sudo vbetool dpms on
Or off:
sudo vbetool dpms off
I have made a unity launcher to turn off the LCD
sudo apt-get install --no-install-recommends gnome-panel
gnome-desktop-item-edit ~/Desktop/ --create-new
It will open a small windows. Enter the following:
Command: gnome-screensaver-command --lock && sleep 2s && xset dpms force off
You can also choose an icon by clicking the icon on the left .
For more on making launcher see http://www.ubuntugeek.com/how-to-create-desktop-launchers-in-ubuntu-11-10oneiric.html.
(sleep 10; xset dpms force suspend) & xdg-screensaver lock
This starts the screen saver in locked mode and then puts your display in standby. Ubuntu Mate 15.10
wjandrea
  • 14,504
blazedego
  • 171
xset dpms force off worked only for 5 seconds.
I searched the internet and found the following script, and after a small change it worked perfectly.
#!/usr/bin/python
import time
import subprocess
from Xlib import X
from Xlib.display import Display
display = Display(':0')
root = display.screen().root
root.grab_pointer(True,
       X.ButtonPressMask | X.ButtonReleaseMask | X.PointerMotionMask,
       X.GrabModeAsync, X.GrabModeAsync, 0, 0, X.CurrentTime)
root.grab_keyboard(True,
       X.GrabModeAsync, X.GrabModeAsync, X.CurrentTime)
subprocess.call('xset dpms force off'.split())
#original
#p = subprocess.Popen('gnome-screensaver-command -a'.split())
#changed
p = subprocess.Popen('xset dpms force off'.split())
time.sleep(1)
while True:
   print display.next_event()
   p.terminate()
   break
derHugo
  • 3,376
  • 34
  • 52
Mario
I know that xscreensaver is not exactly blank screen, but may be of some help:
xscreensaver-command -activate
or via ssh
DISPLAY=:0 xscreensaver-command -activate
The same way deactivate:
DISPLAY=:0 xscreensaver-command -deactivate
or
export DISPLAY=:0
Enter password after xscreensaver via ssh:
DISPLAY=:0 xdotool type Ctrl # wake up from screensaver
   or: DISPLAY=:0 xdotool click 1
DISPLAY=:0 xdotool type "passwordovich"
DISPLAY=:0 xdotool type Return # Enter
xerostomus
  • 1,060
If everything else fails:
gsettings set org.gnome.desktop.session idle-delay 30
... and then wait 30 seconds :-(
Note you must be logged in.
PS: values below 30 seconds seem silently bumped to 30 seconds?
MarcH
  • 121
