I am trying to install php curl like so:
sudo apt-get update
sudo apt-get install php5-curl
But I keep getting an error.
Reading package lists... Done
Building dependency tree
php5-curl is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
Setting up runit (2.1.2-3ubuntu1) ...
start: Unable to connect to Upstart: Failed to connect to socket /com/ubuntu/upstart: Connection refused
dpkg: error processing package runit (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of git-daemon-run:
 git-daemon-run depends on runit; however:
  Package runit is not configured yet.
dpkg: error processing package git-daemon-run (--configure):
 dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
 runit
 git-daemon-run
when I try sudo dpkg --configure -a I get:
 git-daemon-run
when I try sudo apt-get install --reinstall runit I get:
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 8 not upgraded.
E: Internal Error, No file name for runit:amd64
when I try sudo apt-get install runit I get:
runit is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 8 not upgraded.
start: Job is already running: runsvdir
 runit
 git-daemon-run
when I try sudo apt-get install --reinstall git-daemon-run I get:
E: Internal Error, No file name for git-daemon-run:amd64
How can I fix this?
System Specs:
Processor: Intel® Core™ i7-3630QM CPU @ 2.40GHz × 8
Graphics: Gallium 0.4 on AMD TURKS (DRM 2.43.0, LLVM 3.6.2)
OS Type: Ubuntu 15.10 64-bit
Waqleh
  • 911
I forcibly remove runit like so:
sudo dpkg -r --force-all runit
then
sudo apt-get -f install runit
then installed php-curl:
And it was fixed.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Waqleh
  • 911
Install git-daemon-sysvinit first.
sudo apt-get install git-daemon-sysvinit
Then install php5-curl.
git-daemon-sysvinit replaces git-daemon-run. (They are alternatives for each other.) git-daemon-run doesn't actually work anymore on Ubuntu 15.04 and up, from my experience, and from what I have read. At least, not without special handling. (https://bugs.launchpad.net/ubuntu/+source/runit/+bug/1448164)
