I am trying to install git-all using the following commands:
sudo apt update
sudo apt install git-all
and I get the following results:
jonathan@Aristotle:~$ sudo apt install git-all
Reading package lists... Done
Building dependency tree
git-all is already the newest version (1:2.7.4-0ubuntu1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up runit (2.1.2-3ubuntu1) ...
start: Unable to connect to Upstart: Failed to connect to socket /com/ubuntu/upstart: Connection refused
dpkg: error processing package runit (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of git-daemon-run:
 git-daemon-run depends on runit; however:
  Package runit is not configured yet.
dpkg: error processing package git-daemon-run (--configure):
 dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
 runit
 git-daemon-run
I found this response to a similar question: http://askubuntu.com/questions/728581/how-to-fix-error-processing-package-git-daemon-run/728748#728748 but none of the solutions mentioned in it worked for me. Any ideas on how I can proceed from here?
Jonathan
  • 1,498
I discovered that this is a Ubuntu bug that has been reported as https://bugs.launchpad.net/ubuntu/+source/runit/+bug/1448164.
The problem exists because runit depends on upstart and Ubuntu changed to using systemd in 15.04. The workaround is as follows:
sudo apt-get purge runit
sudo apt-get purge git-all
sudo apt-get autoremove
sudo apt update
Basically you completely get rid of runit, git-all and git, cleanup the apt database and then re-install git. Instead of installing git-all again cherry pick the packages that you actually need and install those.
Jonathan
  • 1,498
Get rid of runit and git-daemon-run. Install git-daemon-sysvinit instead. git-daemon-sysvinit is an alternative for git-daemon-run, and it actually works on Ubuntu 15.04 and up.
Once you install git-daemon-sysvinit, the dependencies for git-all should be met, and you can proceed.
I had the same problem while trying to install all packages of git on Ubuntu 16.04 LTS. This is what I did:
sudo apt update
sudo apt-get install git-daemon-sysvinit
sudo apt-get install git-all
I wrote this bit of code based on the two posts above by Johnathon and Stephen.It worked for me!
