When you first look at this question and its title you are going to assume that I want this for malicious purposes, however that is not the case, it is because I type a lot of things, and sometimes (rather often actually) I just want to check what I did, say, half an hour ago, or make sure that I didn't just make a big mistake, however there is no real history of what I type so this becomes rather difficult.
Another reason for this might be that my computer is running certain tasks which should not be interrupted until complete, so I can't suspend my machine, but I would like to be able to come back and tell if anybody typed anything (because most often this is a CLI only session so I don't need to worry about the mouse and I can use other software such as screen recording for that), or executed any keyboard shortcuts.
So, long story short, I would like a "keylogger" however I do not want to install one from anywhere as I don't trust that there aren't any backdoors or anything, so what I would like is a script (and I know that this sort of thing is possible) which:
  • Is able to record (probably in a text file) keystrokes and also when the pressing of a key once results in the character coming out more than once
  • Is able to tell apart keyboard shortcuts from normal typing and also show what the result of the keyboard shortcut was
  • Works in the GUI and CLI
  • Works on Ubuntu GNOME 15.10 with GNOME 3.18 (my system)
  • Preferably written in a language such as bash
  • Only keeps a log of the last 5 minutes (though this should be a variable time which can be easily changed in the code)
cl-netbox
  • 31,491
