18
Since I have installed Ubuntu 15.10 I can no longer add ppa to my repository list:
@:~>sudo apt-add-repository ppa:git-core/ppa
Cannot add PPA: 'ppa:~git-core/ubuntu/ppa'.
ERROR: '~git-core' user or team does not exist.
Does somebody know what changed in 15.10? Maybe it is an issue with a proxy-server. I am behind a proxy server, but everything else like wget or apt-get is working with my current configuration.
Sven
  • 291
You need to export environment variable first. Open a terminal and run:
export http_proxy="http://username:password@proxy:port/"
export https_proxy="https://username:password@proxy:port/"
Now add the PPA:
sudo -E add-apt-repository ppa:git-core/ppa
You will get a prompt:
➜  ~ sudo -E apt-add-repository ppa:git-core/ppa
 The most current stable version of Git for Ubuntu.
For release candidates, go to https://launchpad.net/~git-core/+archive/candidate .
 More info: https://launchpad.net/~git-core/+archive/ubuntu/ppa
Press [ENTER] to continue or ctrl-c to cancel adding it
Press Enter and you will be able to install from a PPA.
Chai T. Rex
  • 5,323
alphaguy
  • 291
OP's answer
I found the problem, it was really related to the proxy-server but with a different background. Our server uses authentication which was not set up here. After disabling it, the problem went away. The strange think is the misleading error message. So hopefully this will read somebody in the future with the same problem.
Pilot6
  • 92,041
