I want to use ondrej ppa to upgrade php version in ubuntu server. I have connected to internet connection.
sudo apt-get install python-software-properties
sudo add-apt-repository ppa:ondrej/php
I tried and got an error:
Cannot add PPA: 'ppa:ondrej/ubuntu/php'
'ondrej' user or team does not exist
I had tried using -E in the command and the error is the same.
about the proxy setting, I do not really understand. I do not know how to adjust the setting according the answer in here
I also tried this:
RUN apt-get -y install locales
RUN locale-gen en_US.UTF-8
ENV LANG en_US.UTF-8
ENV LANGUAGE en_US:en
ENV LC_ALL en_US.UTF-8
RUN add-apt-repository -y ppa:ondrej/php
but the result is the same, the error cannot add ppa:ondrej
Thank you
wjandrea
  • 14,504
joun
  • 153
Apparently it was an issue with DNS or the server was down because the commands you posted are now working successfully.
After the update, sudo apt install php installed the latest PHP version (currently 7.3)
damadam
  • 2,873
Wildhair
Maybe the problem is caused by
  • your locale (language etc)
  • your computer's internet connection
  • some [other] installed PPA or program package
I tried with a live Ubuntu 16.04.1 LTS, and I could add the repository ppa:ondrej/php.
There was a warning: 'add-apt-repository is broken with non-UTF-8 locales.' and a tip with a work-around. See below.
ubuntu@ubuntu:~$ sudo add-apt-repository ppa:ondrej/php
 Co-installable PHP versions: PHP 5.6, PHP 7.x and most requested extensions
 are included. Only Supported Versions of PHP
 (http://php.net/supported-versions.php) for Supported Ubuntu Releases
 (https://wiki.ubuntu.com/Releases) are provided. Don't ask for end-of-life
 PHP versions or Ubuntu release, they won't be provided.
Debian oldstable and stable packages are provided as well: https://deb.sury.org/#debian-dpa
You can get more information about the packages at https://deb.sury.org
BUGS&FEATURES: This PPA now has a issue tracker:
https://deb.sury.org/#bug-reporting
CAVEATS:
1. If you are using php-gearman, you need to add ppa:ondrej/pkg-gearman
2. If you are using apache2, you are advised to add ppa:ondrej/apache2
3. If you are using nginx, you are advise to add ppa:ondrej/nginx-mainline
   or ppa:ondrej/nginx
PLEASE READ: If you like my work and want to give me a little motivation, please consider donating regularly: https://donate.sury.org/
WARNING: add-apt-repository is broken with non-UTF-8 locales, see
https://github.com/oerdnj/deb.sury.org/issues/56 for workaround:
# LC_ALL=C.UTF-8 add-apt-repository ppa:ondrej/php
 More info: https://launchpad.net/~ondrej/+archive/ubuntu/php
Press [ENTER] to continue or ctrl-c to cancel adding it
gpg: keyring `/tmp/tmppiurqcxa/secring.gpg' created
gpg: keyring `/tmp/tmppiurqcxa/pubring.gpg' created
gpg: requesting key E5267A6C from hkp server keyserver.ubuntu.com
gpg: /tmp/tmppiurqcxa/trustdb.gpg: trustdb created
gpg: key E5267A6C: public key "Launchpad PPA for Ondřej Surý" imported
gpg: Total number processed: 1
gpg:               imported: 1  (RSA: 1)
OK
sudodus
  • 47,684
