I am trying to get Ubuntu version 14.04.1 running on a Windows 7 64 bit system. The Oracle VirtualBox is version 5.0.12r104815.
From a terminal window in Ubuntu I am able to ping google.com and other addresses. But I cannot get the system to update or install other software.
I have the default horrible 640x480 resolution which I cannot change and want to install the tools to change the resolution.
sudo apt-get install virtualbox-guest-dkms virtualbox-guest-x11
I get an instant response:
Reading package lists... Done
Building dependency tree
E: Unable to locate package virtualbox-guest-dkms
E: Unable to locate package virtualbox-guest-x11
When I try to run an update:
sudo apt-get update
The response is a continuous:
0% [Connecting to gb.archive.ubuntu.com (91.189.92.201...
I can't open google.com in firefox either, yet I can ping google.com
I have setup the system with the correct company DNS address. All the host names and addresses will ping ok, but I can't get any data response back to the system. I suspect it is a firewall problem. The companies IT dept has experience in Windows only, what ports do I need to ensure are opened?
