I found few threads that explain how to reinstall grub2 by the mean of chroot but none of them explain how to proceed if my / is encrypted and if there is a plain /boot partition. Thing is I installed Debian in EFI mode and it made an unbootable entry (Japanese character) in the UEFI boot menu.
I tried to make a new entry using efibootmgr from Ubuntu liveUSB but it is still unbootable. I'd like to reinstall grub from Ubuntu liveUSB but I don't know to chroot the encrypted / partition and how the separate /boot partition blends in.
Thomas W.
  • 540
  1. Boot from an Ubuntu Live USB with a working internet connection.
  2. Open a Terminal window (ApplicationsAccessoriesTerminal).
  3. Type the following commands (pay attention to the comments, starting with #, after some commands):
    sudo -i
    apt-get update
    apt-get install cryptsetup lvm2
    fdisk -l
    cryptsetup luksOpen /dev/sda? TAG           # sda? is your root partition
    vgchange -ay
    vgscan
    vgchange -ay [VOLUME GROUP NAME]           # From the above command
    lvscan
    mount /dev/[VOLUME GROUP NAME]/[LOGICAL VOLUME NAME] /mnt          # LOGICAL VOLUME NAME from above command
    modprobe efivars
    mount /dev/sda? /mnt/boot/efi          # sda? is your efi partition
    mount --bind /dev /mnt/dev
    mount --bind /dev/pts /mnt/dev/pts
    mount --bind /proc /mnt/proc
    mount --bind /sys /mnt/sys
    cp /etc/resolv.conf /mnt/etc/
    chroot /mnt
    then do
    apt-get install --reinstall grub-efi-amd64
    or
    and continue with
    update-grub
    umount /mnt
    vgchange -an
    cryptsetup luksClose TAG
kyodake
  • 17,808
Took me a while getting lost doing this. I have the same setup (non-encrypted /boot in ADDITION to a vfat /boot/efi). The following debian guide nails it. Missing pieces from all other guides were mounting the efivars and just comprehensive steps for grub re-installing etc. Hope this helps!
https://wiki.debian.org/GrubEFIReinstall
Details on the specific parts that were missing from other answers here:
  • include the efivars in the chroot whole installing grub
    for i in /dev /dev/pts /proc /sys /sys/firmware/efi/efivars /run; do sudo mount -B $i /mnt$i; done
  • don't forget to mount /boot and then also /boot/efi in the chroot
  • run *all the grub commands
    grub-install /dev/disk
    update-grub
Thank you debian!!
