I recently changed from a 3.5 to 2.5 inch HDD on my computer and also went from ubuntu 14.04 to 16.04. Now when I try to mount the old HDD I get the following:
  sudo mount /dev/sda /mnt/oldhome
      mount: wrong fs type, bad option, bad superblock on /dev/sda,
      missing codepage or helper program, or other error
   In some cases useful info is found in syslog - try
   dmesg | tail or so.
When I do that I get the following log output:
[ 1474.327826] EXT4-fs (sda2): unable to read superblock
[ 1474.327924] EXT4-fs (sda2): unable to read superblock
[ 1474.328007] EXT4-fs (sda2): unable to read superblock
[ 1892.657070] EXT4-fs (sda): VFS: Can't find ext4 filesystem
fdisk -l gives me the following output:
Disk /dev/sda: 931.5 GiB, 1000204886016 bytes, 1953525168 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
Disk identifier: 0x00005dd2
Device     Boot  Start        End    Sectors   Size Id Type
/dev/sda1  *      2048     499711     497664   243M 83 Linux
/dev/sda2       501758 1953523711 1953021954 931.3G  5 Extended
/dev/sda5       501760 1953523711 1953021952 931.3G 8e Linux LVM
Partition 2 does not start on physical sector boundary.
I hope that you can help me with this tiny, but annyoing problem!
You need to mount the partition, not the block device (hard disk).
For example;
sudo mount /dev/sda1 /mnt/oldhome/
You will not be able to mount /dev/sda2 because that is the extended partition (which means that other partitions, starting from /dev/sda5, reside within it).
To mount /dev/sda5, you might have to use LVM commands, not sure. (I'm not an expert with LVM, so hopefully someone else will help you out with /dev/sda5). You will probably need to mount /dev/md-x to somewhere (with 'x' being a number such as /dev/dm-127.
I had a very quick search on the internet and here is the first link I found.
https://sathyasays.com/2008/10/01/how-tomounting-lvm-partitions-from-a-command-prompt-or-a-root-shell/
hatterman
  • 2,330
