I'm new to Ubuntu environment, its been bothering me since a while.
have tried almost everything suggested in the forums but no luck. I don't know if I'm missing something.
OS: Ubuntu 14.04.1 LTS 64bit
~$ sudo apt-get install openssh-server
Reading package lists... Done
Building dependency tree
 openssh-server : Depends: libck-connector0 (>= 0.2.1) but it is not installable
                  Recommends: ncurses-term but it is not installable
                  Recommends: ssh-import-id but it is not installable
Byte Commander
  • 110,243
got it !!, I downloaded the libck-connector0 from Ubuntu package repository , installed it using sudo dpkg -i libck-connector0_0.4.5-2ubuntu0.1_amd64.deb and then tried it again. It worked this time.
and check this link How do I resolve unmet dependencies after adding a PPA?, this guy covered all possible scenarios for such errors.
