I'm using crouton which enables me to run 14.04 on my Chromebook. I opted to not install a desktop to save disk space so used the cli-extra target when installing:
sudo sh ~/Downloads/crouton -r trusty -t cli-extra -n cli
I can now run sudo enter-chroot from my Chrome OS shell.
My question
Is it possible to launch graphical programs such as gedit? When I use LXDE on another system, I can run gksudo gedit to launch the program but this command isn't recognised in this case. Also, running sudo gedit results in the message "Cannot open display:".
The Xorg server is what takes care of drawing a graphical environment. When Xorg is launched, it also launches an application with a GUI. When this application exits, so does Xorg (if I recall correctly). In Ubuntu, this application is the Unity desktop environment.
You should be able to install a barebones Xorg server, and use the command line (I think xinit gedit should do it) to make it launch the application you want. Alternatively, you can install a lightweight window manager like Openbox. These are typically less user-friendly than full-blown desktop environments like Gnome, Unity and KDE Plasma, but they are also a lot smaller and faster.
RobinJ
  • 9,020
You can run them on a virtual server:
Install:
xorg-server-xvfb
Then run:
xvfb-run [command]
