To give you a little background: I am currently running on Ubuntu 14.04 LTS and want to use the application pan newsreader. Unfortunately if I install that via the Ubuntu Software Center, I get pan 0.139-2, which crashes, when I run it.
[GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name news.pan.NZB
was not provided by any .service files
ERROR:pan-tree.cc:80:GtkTreeIter PanTreeStore::get_iter(const
PanTreeStore::Row*): assertion failed: (row)
Aborted (core dumped)]
So I decided to install a development build from source code.
So I went: git clone git://git.gnome.org/pan2
and after some problems I got ./autogen.sh; make to work. I rebooted several times in between these things and now the application seems to be set up properly.
The executable to open should be /pan2/pan/gui/pan.
I tried *rightclick run, but nothing opened. If I enter pan in the terminal, I am told to download pan 0.139-2 (The version that crashes). Due to lack of understanding basically how a computer works, I then went: cd ~/pan2/pan/gui and then entered ./pan.run, which I read up somewhere on the internet, but it said there was no such file in that directory.
Every advice is greatly appreciated!
Thanks!
Gratis
@Olimjon: You were right; i did not yet do make install, because i thought the ;make before did that, but anyway.
And Takkat was right, too. After that I got the same error.
Now I want to install version 0.139-0 as you did. The easiest way to do that seems to be: How to downgrade packages on Ubuntu?
Unfortunately I only have version 0.139-2 in my repositories. Which repositories do I have to add to be able to install version 0.139-0?
Thanks to everyone!
you must get build-essentials ,gcc and cmake packages first.
sudo apt-get updat && sudo apt-get install -y build-essential gcc cmake
after that , goto the program directory you have excuated , and write
sudo cmake configurationfilename
and then
sudo make
sudo make install
best regards,
