I can't change the brightness on my Vaio VGN-FZ340E. There isn't even a slider on the screens window. The only way I've found to do it is to use smartdimmer throught the command line, however this is pretty inconvenient. any help would be appreciated.
zmanian
  • 303
Alex
(SOLVED) Please see the link
http://ubuntuforums.org/showthread.php?t=1004568&page=3
I have Sony Vaio VGN FZ340E and after long search I found the solution in the following link
http://doube.org/karmic-vaio
and now its working perfect without any problem I've only changed the (the SPIC to SNC) for both files
sony-brightness-up
sony-brightness-down
Shown expression
for sony-brightness-up file
event=sony/hotkey SPIC 00000001 00000011
I used the following expression
event=sony/hotkey SNC 00000001 00000011
for sony-brightness-down file
event=sony/hotkey SPIC 00000001 00000010
event=sony/hotkey SNC 00000001 00000010
Backlight
Backlight support for Vaios is now incorporated in nvclock Make sure you have nvclock installed for basic backlight control, and until HAL has been updated you have to specify the hotkey event manually.
sudo apt-get install nvclock
nvclock -S 100
nvclock -S 15
nvclock -S +10
Enable the "brighter" hotkey:
sudo gedit /etc/acpi/events/sony-brightness-up
put this text into it:
action=/usr/bin/nvclock -S +10
And the "dimmer" hotkey:
sudo gedit /etc/acpi/events/sony-brightness-down
action=/usr/bin/nvclock -S -10
Make the scripts executable
sudo chmod +x /etc/acpi/events/sony-brightness-*
Restart acpid
sudo /etc/init.d/acpid restart
If you have a different model, you might have different keys controlling your backlight. To check the event ID, run
acpi_listen
Jorge Castro
  • 73,717
Other Solution Which is better visit this link :
Brightness not working after installing NVIDIA driver
Just Download the following file https://github.com/downloads/guillaumezin/nvidiabl/nvidiabl-dkms_0.72_all.deb
Then run the following in the terminal
echo "nvidiabl" | sudo tee -a /etc/modules
