I just installed Linux on my 2010 MacBookPro (triple boot using refind) and get the infamous black screen after installing the nvidia drivers.
I tried applying the solution metioned here:https://askubuntu.com/a/613573/488420 without success.
I wonder if I got the IDs for setpci right. Anyone can confirm?
I'm pasting below the lshw display output and my /etc/grub.d/01_enable_vga.conf file.
Thanks!
mint@mint-MacBookPro ~ $ sudo lshw -businfo -class bridge -class display
información del Bus  Dispositivo  Clase       Descripción
pci@0000:00:00.0                   bridge      Core Processor DRAM Controller
pci@0000:00:01.0                   bridge      Core Processor PCI Express x16 Root Port
pci@0000:01:00.0                   display     GT216M [GeForce GT 330M]
pci@0000:00:02.0                   display     Core Processor Integrated Graphics Controller
pci@0000:00:1c.0                   bridge      5 Series/3400 Series Chipset PCI Express Root Port 1
pci@0000:00:1c.1                   bridge      5 Series/3400 Series Chipset PCI Express Root Port 2
pci@0000:00:1c.2                   bridge      5 Series/3400 Series Chipset PCI Express Root Port 3
pci@0000:00:1c.3                   bridge      5 Series/3400 Series Chipset PCI Express Root Port 4
pci@0000:00:1e.0                   bridge      82801 Mobile PCI Bridge
pci@0000:00:1f.0                   bridge      Mobile 5 Series Chipset LPC Interface Controller
pci@0000:ff:00.0                   bridge      Core Processor QuickPath Architecture Generic Non-core Registers
pci@0000:ff:00.1                   bridge      Core Processor QuickPath Architecture System Address Decoder
pci@0000:ff:02.0                   bridge      Core Processor QPI Link 0
pci@0000:ff:02.1                   bridge      Core Processor QPI Physical 0
pci@0000:ff:02.2                   bridge      Core Processor Reserved
pci@0000:ff:02.3                   bridge      Core Processor Reserved
mint@mint-MacBookPro ~  sudo cat /etc/grub.d/01_enable_vga.conf
cat << EOF
setpci -s "00:01.0" 3e.b=8
setpci -s "01:00.0" 04.b=7
EOF
Joe
  • 103
I finally solved the problem when setpci doesn't change the value of PCI-E bridge.
If you are unable to set the value of PCI-E brigde registers using setpci command in order to get nVidia GeForce drivers working on your Apple MacBook machine try these steps:
1. Find your PCI-E bus identifiers
[root@kernelLinux]# lshw -businfo -class bridge -class display
Bus info          Device      Class          Description
pci@0000:00:00.0              bridge         MCP89 HOST Bridge
pci@0000:00:03.0              bridge         MCP89 LPC Bridge
pci@0000:00:15.0              bridge         NVIDIA Corporation
pci@0000:00:17.0              bridge         MCP89 PCI Express Bridge
pci@0000:02:00.0              display        MCP89 [GeForce 320M]
You will need the ID's of PCI Express Bridge and your display in format XX:XX.X
Your ID's can be different.
In this example our ID's are 00:17.0 for PCI-E brige and 02:00.0 for display [GPU].
2. Create a GRUB script
Our script will be slightly different than in mentioned post above.
I have noticed of two things. Grub2 installed using distro (mine is Centos) installation process doesn't contain setpci grub module. It's the reason why grub do not change registers while boot. Then It is necessary to load setpci module into grub before we run commands to change registers.
Download grub2-efi-modules
Ubuntu Linux
sudo apt-get install grub-efi-amd64-bin
Fedora Linux
sudo dnf install grub2-efi-modules
CentOS Linux
sudo yum install grub2-efi-modules
Modules will be installed in /usr/lib/grub/x86_64-efi/ but the setpci module files needs to be present in /boot/efi/EFI/centos/x86_64-efi/
Create x86_64-efi folder
sudo mkdir /boot/EFI/centos/x86_64-efi
Copy setpci module files into grub2 folder
sudo cp /usr/lib/grub/x86_64-efi/setpci.* /boot/EFI/centos/x86_64-efi
Create the 01_enable_vga.conf file.
The file should contain these lines of code:
Do not forget replace 00:17.0 for PCI-bridge and 02:00.0 for display [GPU] with your values.
sudo nano /etc/grub.d/01_enable_vga.conf
cat << EOF
insmod setpci
setpci -s "00:17.0" 3e.b=8
setpci -s "02:00.0" 04.b=7
EOF
Then repair permissions
sudo chmod 755 /etc/grub.d/01_enable_vga.conf
and update the /boot/efi/EFI/centos/grub.cfg
Ubuntu Linux
sudo update-grub
Do this command only on other distributions (not necessary on Ubuntu after update-grub):
grub2-mkconfig -o /boot/efi/EFI/centos/grub.cfg
3. Reboot your system and check registers
Reboot your machine and check if it's working. Replace ID's with yours again. Your terminal should finally show 08 (PCI-E bridge) and 07 (GPU).
sudo setpci -s "00:17.0" 3e.b
08
sudo setpci -s "02:00.0" 04.b
07
4. Install nVidia drivers
Screenshot: https://i.sstatic.net/nim4Z.jpg
ylwghst
  • 59
Comparing your lshw output with my original approach, it appears you're using a different Macbook Pro - yours is more recent and has one integrated and one discrete graphics card (NVIDIA GT 330M). I doubt that my solution for the Macbook Pro 7,1 (mid-2010, with only NVIDIA 320M) is applicable for your hardware.
Actually, I suspect that the root cause of your black screen is that the discrete NVIDIA 330 GT is disabled during EFI Linux boot. Hence, you would rather have to explicitly enable the discrete NVIDIA card using a different GRUB script. Initial pointers on how to achieve this would be https://discussions.apple.com/message/19065782#19065782 and https://help.ubuntu.com/community/UEFIBooting.
Due to the fact that I don't own that particular hardware, I am not sure whether these are the right settings.
Andreas
  • 546
You might try uncommenting the spoof_osx_version option in refind.conf. This might get the video working for your system, but I can't promise it will work. See the comments in refind.conf or in the rEFInd documentation for details on how this option works.
Note that this option might work differently depending on how you launch Linux -- that is, via BIOS-mode GRUB, EFI-mode GRUB, launching a kernel directly, etc. Also, note that the GRUB changes you're making will work only if you're booting Linux via GRUB. It's not clear if you're doing that. Please see the Methods of Booting Linux section of the rEFInd documentation to learn more about different ways of launching Linux from rEFInd.
Rod Smith
  • 45,120
  • 66
  • 108
