I want to get MacPro 5.1 working with my two NVIDIA 1080 Ti cards. I have the original 9500GT installed as well, so i was able to install Ubuntu and NVIDIA drivers. I get a picture out from 9500GT but not from the 1080 Ti cards. Nvidia X server window is totally empty. nvidia-smi shows both cards, as shown below, so i think the problem shouldn't be the drivers.
MacPro:/$ nvidia-smi
Tue Apr  7 11:08:41 2020
| NVIDIA-SMI 435.21       Driver Version: 435.21       CUDA Version: 10.1     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|   0  GeForce GTX 108...  Off  | 00000000:05:00.0 Off |                  N/A |
|  0%   34C    P5    20W / 280W |      0MiB / 11178MiB |      0%      Default |
|   1  GeForce GTX 108...  Off  | 00000000:06:00.0 Off |                  N/A |
|  0%   33C    P5    27W / 280W |      0MiB / 11178MiB |      0%      Default |
| Processes:                                                       GPU Memory |
|  GPU       PID   Type   Process name                             Usage      |
|  No running processes found                                                 |
I noticed MacBook Pro, EFI and Nvidia setpci IDs but since NVIDIA recognize cards, perhaps this should't be the problem?
How may I troubleshoot this and get video from the 1080 Ti cards?
Edit.1
I'm runing GDM Ubuntu 19.10. I updated latest 440 drivers and pulled 9500GT card out. I have 2x30in monitors attached in the second 1080ti. When i boot without 9500, I dont get image anymore. When login screen should come, i see that second monitor activates but lost connection again. I have tried add nomodeset in then grub as in some tutorials ask but no help. Only thing what changed when I pulled 9500 out, nvidia-smi gives some running process now.
Tue Apr  7 12:42:13 2020
| NVIDIA-SMI 440.64       Driver Version: 440.64       CUDA Version: 10.2     |
|  0%   34C    P8    16W / 280W |     16MiB / 11178MiB |      0%      Default |
|  0%   33C    P8    17W / 280W |      2MiB / 11178MiB |      0%      Default |
|    0      1218      G   /usr/lib/xorg/Xorg                             9MiB |
|    0      1295      G   /usr/bin/gnome-shell                           3MiB |
Edit.2
It seems that sudo get-edid | parse-edid gets monitor info (4k monitor)
Section "Monitor"
        Identifier "U32J59x"
        ModelName "U32J59x"
        VendorName "SAM"
        # Monitor Manufactured week 1 of 2019
        # EDID version 1.3
        # Digital Display
        DisplaySize 700 390
        Gamma 2.20
        Option "DPMS" "true"
        Horizsync 30-135
        VertRefresh 24-75
        # Maximum pixel clock is 600MHz
        #Not giving standard mode: 1152x864, 75Hz
        #Not giving standard mode: 1280x800, 60Hz
        #Not giving standard mode: 1280x720, 60Hz
        #Not giving standard mode: 1280x1024, 60Hz
        #Not giving standard mode: 1440x900, 60Hz
        #Not giving standard mode: 1600x900, 60Hz
        #Not giving standard mode: 1680x1050, 60Hz
        #Extension block found. Parsing...
#WARNING: I may have missed a mode (CEA mode 97)
#DOUBLE WARNING: It's your first mode, too, so this may actually be important.
#WARNING: I may have missed a mode (CEA mode 95)
#WARNING: I may have missed a mode (CEA mode 96)
#WARNING: I may have missed a mode (CEA mode 93)
#WARNING: I may have missed a mode (CEA mode 94)
        Modeline        "Mode 1" 27.000 720 732 796 864 576 581 586 625 -hsync -vsync
        Modeline        "Mode 0" 594.00 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync
        Modeline        "Mode 2" 27.027 720 736 798 858 480 489 495 525 -hsync -vsync
        Modeline        "Mode 3" 74.250 1280 1720 1760 1980 720 725 730 750 +hsync +vsync
        Modeline        "Mode 4" 74.250 1280 1390 1420 1650 720 725 730 750 +hsync +vsync
        Modeline        "Mode 5" 74.250 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync
        Modeline        "Mode 6" 74.250 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
        Modeline        "Mode 7" 148.500 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync
        Modeline        "Mode 8" 148.500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
        Modeline        "Mode 9" 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
        Modeline        "Mode 10" 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync
        Modeline        "Mode 11" 297.00 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync
        Modeline        "Mode 12" 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync
        Option "PreferredMode" "Mode 1"
EndSection
Edit3.
I got it work! Stupid thing and amateur mistake, I had to change cables to second 1080ti. Now both monitors get 4k resolution!
