18
In Linux shell, am I able to create a directory but the name would be a string returned from another program? And if I am able, how to?
In particular I am asked to create a new directory in my Home, and its name would be the minute on my computer's clock. Let's suppose /home/john/01/, 01 is the minutes on my clock.
I was thinking something like pipeline date +"%M" | mkdir but I do not know how I am gonna put that returned number into the mkdir program.
Finally another idea came to my mind, something like this mkdir (date +"%M") but this as well is a mistake. Any help please?
muru
  • 207,228
Mr T
  • 333
The concept you're looking for is command substitution, which uses the syntax $(command)
mkdir /home/john/$(date +%M)
You may also see the older 'backtick' syntax, `command`
steeldriver
  • 142,475
23
mkdir $(date +%Y%m%d) or I personally use mkdir $(date +%Y%m%d_%H%M%S) for hh:mm:ss. date --help will give you the different formats if you need something more.
terdon
  • 104,119
10
You can do it easily using following command:
$ min=$(date +"+%M"); mkdir $min
Humble
  • 153
You can do that by typing the following command:
mkdir ~/$(date | awk -F':' '{print $2}')
The command creates a directory in home folder and gives the current minute as name.
Raphael
  • 8,135
