You can use Command Substitution to get the current date and time when your script is run:
git commit -m "$(date +"%D %T")"
Alternatively you could save date's output in a variable, e.g. if you want to capture the time the script was started at, add as the first command e.g.
timestamp=$(date +"%D %T")
and use it later like:
git commit -m "$timestamp: Backup"
If this is really your whole script, remember to add a Shebang as the first line. I always try to avoid cd in scripts and rather give full paths, last but not least it helps to keep the code clean and easily understandable if you store long paths in variables:
#!/bin/bash
path1=/var/www/html/myweb
path2=/home/myweb/backups/myweb
php "$path1/bin/magento" setup:backup --code --media --db
cp "$path1/var/backups/*" "$path2/backups/"
git add "$path2"
git push
Note that you can't use ~ in a path when you do it like that because variables are expanded after the tilde, you can use $HOME though.
