I get this error when I try and install it:
$ sudo apt-get install ubuntustudio-audio
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies.
 ubuntustudio-audio : Depends: libavdevice-extra-53 but it is not going to be installed
                      Depends: libavfilter-extra-3 but it is not going to be installed
                      Depends: libavformat-extra-54 but it is not going to be installed
                      Depends: libavutil-extra-52 but it is not going to be installed
                      Depends: libswscale-extra-2 but it is not going to be installed
                      Recommends: ardour3 but it is not going to be installed
                      Recommends: audacity but it is not going to be installed
                      Recommends: idjc but it is not going to be installed
                      Recommends: pd-aubio but it is not going to be installed
                      Recommends: pd-readanysf but it is not going to be installed
At the top of this page - https://wiki.ubuntu.com/UbuntuStudio/PackageList it says =OUTDATED=. I'm not sure if that's referring to the whole page (and why this install isn't working) or if it's just referring to the first thing on there (ubuntustudio-desktop).
David Foerster
  • 36,890
  • 56
  • 97
  • 151
baxx
  • 175
Best way:
sudo add-apt-repository "deb http://security.ubuntu.com/ubuntu trusty-security main universe" && sudo apt-get update
Then,
If the above doesn't work, other way is to download the packages manually and then install it from there. To do so:
mkdir ~/Downloads/ubuntustudio && cd ~/Downloads/ubuntustudio
Downloads the following packages manually (while still in the folder ~/Downloads/ubuntustudio):
security.ubuntu.com libavdevice-extra-53
wget -c http://security.ubuntu.com/ubuntu/pool/universe/liba/libav/libavdevice-extra-53_9.18-0ubuntu0.14.04.1_all.deb
security.ubuntu.com libavfilter-extra-3
wget -c http://security.ubuntu.com/ubuntu/pool/universe/liba/libav/libavfilter-extra-3_9.18-0ubuntu0.14.04.1_all.deb
security.ubuntu.com libavformat-extra-54
wget -c http://security.ubuntu.com/ubuntu/pool/universe/liba/libav/libavformat-extra-54_9.18-0ubuntu0.14.04.1_all.deb
security.ubuntu.com libavutil-extra-52
wget -c http://security.ubuntu.com/ubuntu/pool/universe/liba/libav/libavutil-extra-52_9.18-0ubuntu0.14.04.1_all.deb
security.ubuntu.com libswscale-extra-2
wget -c http://security.ubuntu.com/ubuntu/pool/universe/liba/libav/libswscale-extra-2_9.18-0ubuntu0.14.04.1_all.deb
Then, to install it run:
sudo dpkg -i *.deb
And to satisfy any dependencies, do:
sudo apt-get -f install
Raphael
  • 8,135
