I installed eclipse-java-neon-M3-linux-gtk-x86_64.tar.gz on ubuntu 15.10 by following steps given in response to How to install Eclipse? but now want to completely uninstall it, how to do that? Please help!
Asked
Active
Viewed 4,699 times
If you followed the above link accurately, then to uninstall it, do the following:
Goto the installed folder:
cd /opt && ls | grep eclipse
It will output the name of a folder that says eclipse. Copy the name of that folder.
Now, type the following command to delete it:
sudo rm -rf PASTE THE NAME OF THE FOLDER HERE
sudo rm /usr/local/bin/eclipse44
sudo rm /usr/share/pixmaps/eclipse.xpm
sudo find / -type f -iname eclipse.desktop -delete
sudo rm -rf ~/.eclipse
If you do not need java anymore, then:
sudo apt-get remove --purge openjdk*
Also, if you want to remove your saved projects, then, browse for the folder where you saved it, by default it's in ~/workspaces and type the following:
sudo rm -rf DRAG AND DROP THE FOLDER HERE
EDIT: As pointed by simran-kumari, the plugins still remain after the above process of purging eclipse. To remove the plugins, browse to /usr/lib/jvm/java-8-oracle/lib/missioncontrol/ and delete the relevant files/folders. The command for that is:
sudo find /usr/ -type d -iname '*eclipse*' -delete && sudo find /usr/ -type f -iname '*eclipse*' -delete
