By default Ubuntu has selected the nouveau drivers as i have an nvidia gpu. But I need to run my system on the Intel GPU instead, with Intel drivers etc. How can I do this?
To achieve what you want, you will have to install the proprietary NVIDIA drivers and Optimus.
After that you can switch between the graphics from NVIDIA X Server Settings PRIME Profiles.
Assuming you have a NVIDIA GEFORCE 400 series adapter or newer execute these commands :
sudo apt-get update
sudo apt-get install nvidia-352 nvidia-prime
sudo reboot
Update addressing your response to having problems with 352 drivers
Use another method - first uninstall the formerly installed NVIDIA drivers.
Highlight the Ubuntu entry in the GRUB boot menu and press the E key.
Add nouveau.modeset=0 to the end of the linux line - press F10 to boot.
On login screen press Ctrl+Alt+F1 - enter user name and password - execute :
sudo apt-get purge nvidia*
sudo reboot
Now install the NVIDIA drivers 358 from the Proprietary GPU Drivers PPA.
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo apt-get update
sudo apt-get install nvidia-358 nvidia-prime
sudo reboot
- 31,491
Nvidia settings is available in software center. Install it if not already installed.
sudo apt install nvidia-settings
Now open it by running this in terminal
nvidia-settings
From there you will be able to select which GPU you want to use (Nvidia/Intel).
Go to PRIME Profiles -> Select the GPU you would like to use -> Choose Intel (Power Saving Mode)
- 23
